gator glide https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=31520 |
Page 1 of 2 |
Author: | brianb [ Tue Aug 14, 2012 8:15 pm ] |
Post subject: | gator glide |
ordered some gatorglide today after reading up on it, the owner actually called after i ordered it to make sure i understood how to apply and after discussing my application changed up my order for the new base coat which makes it more durable over a longer period of time, seems like a good product and company to deal with |
Author: | bbb [ Wed Aug 15, 2012 9:10 am ] |
Post subject: | Re: gator glide |
Hard to beat that kind of CS. Plus he's a member on this forum too. |
Author: | BayouBuster [ Wed Aug 15, 2012 9:55 am ] |
I ordered some this past weekend to do some touch up. The owner has emailed me several time discussing how to apply it. He keeps me up to date on my order as well. Why can't everybody have customer service like gator glide? |
Author: | Docott [ Wed Aug 15, 2012 10:10 am ] |
Anybody ever tried Astroglide? |
Author: | Woodiebuster [ Wed Aug 15, 2012 10:44 am ] |
Why cant he spend $200 and Sponsor the site like everybody else? |
Author: | deltaduckmaster [ Wed Aug 15, 2012 11:05 am ] |
Author: | WestEndAngler [ Wed Aug 15, 2012 11:21 am ] |
I remove all of his posts about Gator Glide... If he would just reach out and communicate with Tony or Me so we can get him on board I bet a lot more people would buy his product instead we have to remove posts to protect those sponsors who actually pay. |
Author: | Tony B [ Wed Aug 15, 2012 11:30 am ] |
He's coming on board |
Author: | 3rd Coast Killer [ Wed Aug 15, 2012 11:57 am ] |
Author: | WestEndAngler [ Wed Aug 15, 2012 12:07 pm ] |
Author: | CootSlayerRMFT [ Wed Aug 15, 2012 1:59 pm ] |
Author: | Frog [ Tue Aug 28, 2012 1:45 pm ] |
Hey Guys, If you don't mind I could use some pictures of the application of the GatorGlide and GatorBase for the web page. Especially the boats that did not get flipped over to apply. It would help the new guys see how easy it is to apply and give them an idea of how to do it. You could email them to Gatorheads@comcast.net I would greatly appreciate it. Thank you |
Author: | WestEndAngler [ Tue Aug 28, 2012 1:47 pm ] |
Author: | BayouBuster [ Tue Aug 28, 2012 2:07 pm ] |
If I would have known last week I could have helped you out. |
Author: | marsh chicken [ Tue Aug 28, 2012 8:19 pm ] |
Author: | brianb [ Tue Aug 28, 2012 8:26 pm ] |
i will get some posted in a week or so, applied 3 coats of gatorbase on sunday afternoon, it has to dry 48 hours before applying gatorglide so i had to put it back on trailer this morning due to Issac coming this way. built some A frames out of some #8 rebar i had laying around and used ratchet straps on all four corner cleats and picked it straight up off trailer, it was suspended about 18 inches off of the ground. each coat of gatorbase dried in about 10-20 minutes, the gatorbase is fairly slick, going to have to have is secured good on the trailer for sure especially when i get the g2 applied. |
Author: | Frog [ Fri Aug 31, 2012 4:25 pm ] |
Thanks guy, Hope you all are doing well in LA. Thank you brainb, how are you making out with the storm? I've only received Pictures from Will do far. Thank you Will! I know this storm has put the brakes on everybody right now. I pray everything will turn out well for everyone. |
Author: | brianb [ Fri Aug 31, 2012 4:38 pm ] |
thanks, we made it thru the storm, fine, no damage, actually only got high winds where i live thru the week and 1 inch of rain yesterday, but this morning (friday)we got a lot of rain and the actual storm is in arkansas now, we got up to 8 inches in just a few hours do i need to scuff the gatorbase with sandpaper and wipe with acetone before i apply the gatorglide or just paint it on, plan to do it on saturday if weather is good will get you some pictures then |
Author: | Frog [ Sat Sep 01, 2012 6:14 am ] |
Yes, give it a light sand with either 200 grit or a Scotch Brite pad and wipe with acetone real well then apply GatorGlide slick bottom. The GatorBase dries hard and slick itself so the surface need to be etched so the G2 or G4 will stick. |
Author: | brianb [ Mon Sep 03, 2012 7:58 pm ] |
gator glide applicaton, finally got around to applying the g2 today thru some A frames together from #8 rebar had in the shop |
Author: | brasso [ Mon Sep 03, 2012 10:01 pm ] |
Seeing as in a broke dick and can't afford a true my hull, with this benefit a boat with ribs? |
Author: | CootSlayerRMFT [ Mon Sep 03, 2012 10:16 pm ] |
Sure will. Plenty of people have done it. Anything that you slide over right now, you'll slide over a lot faster and/or easier... |
Author: | brasso [ Mon Sep 03, 2012 11:00 pm ] |
Thanks coot... Yeah I'm planning of getting another boat soon for season, but know I can't afford anything nice like y'all have.. It'll probably be an older Jon with a longtail. I've got a lot of stumps and hard bottoms. If gator glide may help me to conquer this better than what I already have, best beleive I'm investing in it. |
Author: | Will [ Tue Sep 04, 2012 4:08 am ] |
Author: | Frog [ Wed Sep 12, 2012 1:52 pm ] |
I'm getting allot of questions about the GatorBase, what the coverage is and how to order. We put together a GatorBase plus G2 Kit and a GatorBase plus G4 Kit primarily for Mud boats. This is the perfect bottom. Both kits come with a "1/2 gal of the Base and 1/2 gal of the Glide" making it a 1 gal kit. each 1/2 gal covers 100 sq ft 3-5 coats. If you have a 17 X 48 you have 68 sq ft of bottom! You would be well served to put the whole 1/2 gal of GatorBase on but you would not necessarily need to put all the Glide on. Going over the GatorBase you could get by with 1/2 to 3/4 of the 1/2 gal of GatorGlide and save some for touch up. If you have steel flex or similar on the bottom already you do NOT need the GatorBase. You would only need the GatorGlide G4 or G2. |
Author: | bbb [ Wed Sep 12, 2012 6:34 pm ] |
Hmmm. I put the g2 directly on my roughed up bare hull and it's held up great. |
Author: | meterman3 [ Wed Sep 12, 2012 7:40 pm ] |
Yep me to Sent from my DROID RAZR using Tapatalk 2 |
Author: | manzquad [ Thu Sep 13, 2012 2:26 pm ] |
I have a ribbed Beavertail... ![]() Here is an easy way to get it off the trailer and in the air. Open foldable ladder to the scafolding shape. Raise tounge jack up until the bow touches the ladder placed over top. Run a rachet strap thought the ladder to some tie off points. Lower the tounge... walla the front is in the air. For the rear... Run engine hoist around back. Rachet strap to each back corner. Jack it up. There you have it , floating boat. I rolled around underneath it on a creeper. This worked out awesome and quick. |
Author: | CootSlayerRMFT [ Thu Sep 13, 2012 2:37 pm ] |
That looks like it oughta be on the infomercial for those queer ladders... You could be the next Billy Mayes!!! ![]() ![]() |
Author: | Will [ Thu Sep 13, 2012 2:49 pm ] |
Author: | Frog [ Fri Sep 14, 2012 9:37 am ] |
Author: | supercajun [ Fri Sep 14, 2012 5:29 pm ] |
do i have to mix it in batches, one for each coat or can i mix the whole half gallon and just cover it while i wait for the diff coats to dry? |
Author: | brianb [ Fri Sep 14, 2012 6:14 pm ] |
i would only mix it in small batches incase you dont need it all you will have some left for touchups i mixed g2 with a drill, them poured 22 ounces in a paint cup and 4 ounce of hardner mixed it with drill, then poured into a paint roller tray. seems like each batch did 1 to 1.5 coats or so i put 3 coats and had some left for touchups later can get paint cup at automotive paint supply stores or buy them at lowes |
Author: | Frog [ Tue Sep 18, 2012 11:39 am ] |
GatorGlide price increases as of tomorrow 9/19/12. Not my idea but the MFG raw materials gone up so they have done a price increase across the board. |
Author: | Will [ Tue Sep 18, 2012 11:43 am ] |
Author: | Frog [ Tue Sep 18, 2012 1:36 pm ] |
Thanks Will, yes the 19th. How much? It looks like about 10 bucks a gal or 5 a half. I received as much warning as you. |
Author: | Will [ Tue Sep 18, 2012 1:47 pm ] |
Author: | Frog [ Wed Sep 26, 2012 8:59 am ] |
Author: | CootSlayerRMFT [ Mon Nov 19, 2012 5:59 pm ] |
To anyone that doesn't believe that Gator Glide works, try telling that to this guy I met at the boat ramp today that just put it on his boat... **Sent from my Obama Phone** |
Author: | Kmoppert [ Mon Nov 19, 2012 7:20 pm ] |
Yeah, you have GOT to keep that bow line on. I left mine on once without the winch locked and it unspooled the whole thing. Luckily I was over the water when it slid. That stuff is amazing. |
Page 1 of 2 | All times are UTC - 6 hours |
