It is currently Thu Dec 18, 2025 10:23 pm
Reply to topic  [ 6 posts ]
 GTR Reverse
Post GTR Reverse
Is it regular DOT 3 fluid that needs to go in the reverse lever. My lever is starting to touch the tiller when i use reverse. Also will i have to bleed out the lines or just add more fluid to resivoir.
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Tue Jul 14, 2009 1:29 pm
Post Re: GTR Reverse
Tue Jul 14, 2009 1:30 pm
17x48 extreme stage 2 GTR
Tue Jul 14, 2009 4:44 pm
get a 3 blade!
Tue Jul 14, 2009 11:00 pm
When I pass by ur house again I can take a look at it. Pull the belt housing cover off and look at both pads at rest. They should be about 1/16" ish from the rotor. if they are further than that you need to adjust the pads. if they are within spec, we gonna have to add fluid and bleed it. Did i mention i hate bleeding fluids.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Jul 15, 2009 8:43 am
checked it yesrterday. pads need to be adjusted
Wed Jul 15, 2009 9:39 am
