It is currently Fri Jul 25, 2025 8:54 pm
Reply to topic  [ 13 posts ]
 Light bar mount and cover
Post Light bar mount and cover
Ive seen plenty of light bars but I was wondering what some of your ideas are for a bracket or light protector. Most of the lights I've seen mounted on the front have no means of protecting it from limbs, or people falling on it. What did you make yours out of? I like the one from mud buddy or gator trax but they don't sell the brackets alone, it's the whole light kit and all.
Fri Oct 12, 2012 11:06 am
Post Re: Light bar mount and cover
Mine is 5 inches from front to back and I cant remember the rest of the dimensions but It is made of 1/4 aluminum plate. It was cheap you could build one for any size of light bar or set of lights.
Fri Oct 12, 2012 2:55 pm
3/4" schedule 40 steel pipe welded to plates that bolt to some solid spots on the bow. Sum bitch is tough and has saved the GoLight's ass multiple times!
Fri Oct 12, 2012 3:16 pm
Whats that gator got in its mouth a deer or a Nutra?
Running an 1860 Gator Tail Extreme with a 25 Horse Merc
Fri Oct 12, 2012 5:09 pm
A whole freakin deer! He's a dinosaur.
Fri Oct 12, 2012 5:22 pm
coot are u not worried about galvanic corrision bolting steel to aluminium. i would at least install a sacrificial anode. i have also seen where guys use steel rivets in a alum. boat. instead of alum. rivets. not good
JUST ANOTHER FARMER ON WELFARE
Fri Oct 12, 2012 9:46 pm
I was kinda wondering about that. I probably need to mount a zinc up there somewhere, shouldn't I?
Fri Oct 12, 2012 10:57 pm
you could also find an old piece of flat rubber mat and cut out the shape of your mount and slip it between..
Gator Trax Hybrid 1654 HuntDeck
Sat Oct 13, 2012 7:50 am
I like both of those. Thanks for the help guys.
Sat Oct 13, 2012 8:37 am
I need to build one myself. Probably just going to build a removable one but it will be some time before I have access to an aluminum welder.
Sat Oct 13, 2012 10:26 am
swampslut u know of a place that sells rubber screws. cause the reaction will follow the fastner.
Sat Oct 13, 2012 4:50 pm
Sat Oct 13, 2012 7:38 pm
Some kind of spacer is a must to seperate the metals , we use and old plastic 55 gallon barreland cut peice's from that as spacers they work great just use a jigsaw.
1746 with a modded 35 gdsd
Capt Team total asalt
Sat Oct 13, 2012 9:58 pm
Users browsing this forum: No registered users and 116 guests
