35 GTR blowing clutch fuse https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=33724 |
Author: | lngtail24 [ Fri Oct 26, 2012 7:27 pm ] |
Post subject: | 35 GTR blowing clutch fuse |
I've got an 08 model and the last two times I've ran it I blew the fuse. The first time it was only a few min before it blew the second time maybe an hour. I was leaving for out of town the second time so I have not spent much time looking into it just seeing if anyone else has had this while I was still out. Thanks. |
Author: | Team Camo [ Fri Oct 26, 2012 7:33 pm ] |
Post subject: | Re: 35 GTR blowing clutch fuse |
Check for chafed or broken wire grounding out |
Author: | lngtail24 [ Fri Oct 26, 2012 8:06 pm ] |
Yup definitely the first thing ill trace down and eliminate. Thanks |
Author: | deltaduckmaster [ Fri Oct 26, 2012 8:14 pm ] |
Change the fuse holder |
Author: | tacmc6 [ Fri Oct 26, 2012 9:19 pm ] |
I had the same problem, thats what Terry found wrong with mine. Sent from my DROIDX using Tapatalk 2 |
Author: | lngtail24 [ Fri Oct 26, 2012 9:55 pm ] |
Preciate the input. I'll do that as well and repost |
Author: | Gameover [ Sat Oct 27, 2012 5:58 am ] |
Buy a GD no fuses to blow.... |
Author: | lngtail24 [ Sat Oct 27, 2012 7:17 am ] |
That's true no fuses to blow only u-joints ( see cootslayer) ![]() |
Author: | Gameover [ Sat Oct 27, 2012 7:52 am ] |
still only happened once how many times has that fuse blown now? 3,4.... |
Author: | deltaduckmaster [ Sat Oct 27, 2012 8:24 am ] |
Author: | txmudcutter [ Sat Oct 27, 2012 8:44 am ] |
Author: | OwenDickeson [ Sat Oct 27, 2012 9:37 am ] |
I blow fuses in my truck periodically, so should I just buy a bicycle? |
Author: | Robn1020 [ Sat Oct 27, 2012 9:48 am ] |
Author: | cb5331 [ Sat Oct 27, 2012 9:52 am ] |
Every + line off the battery should be fused or protected from a direct short in some way on any motor. Not protecting the wire is a fire hazard and sure seems like a bad idea to me. |
Author: | Gameover [ Sat Oct 27, 2012 11:27 am ] |
Author: | Gigafowl [ Sat Oct 27, 2012 1:41 pm ] |
It's all good - he can just reverse all the way - or at least until the plastic shroud bursts into flames ---- LOL |
Author: | lngtail24 [ Sat Oct 27, 2012 3:02 pm ] |
Changed fuse twice, on the water, probably a good 10-12 seconds downtime. |
Author: | lngtail24 [ Sat Oct 27, 2012 3:04 pm ] |
$6 fuse holder will most likely solve my issue ( 4-6 min labor) |
