It is currently Sat Jul 26, 2025 1:26 pm
Reply to topic  [ 35 posts ]
 not settin any speed records! help!!!
Post not settin any speed records! help!!!
Just finished my surface drive and I went test it yesterday and I'm only getting 8 mph. My ratio is 1.375:1. I'm running a 9x6 prop. The boat is 1436 and the motoe is 13hp. I do have a 10x8 prop. Do you think this is right or do I need to put the bigger prop on it? Will it make a difference?
35 GTR chasin a BBC 1848
Mon Oct 29, 2012 8:23 am
Post Re: not settin any speed records! help!!!
What is your rpm?
Mon Oct 29, 2012 10:49 am
are you using a surface drive prop or a longtail prop? you prolly wont get more than 12mph at most with everything perfect....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Mon Oct 29, 2012 10:52 am
not sure on the rpm, waiting on tach in mail. the 9x6 is a longtail prop. i had it on a longtail and i was pullin 15-17mph. maybe my gearing is screwed up?
Mon Oct 29, 2012 11:05 am
Prop has a lot to do with it.
Mon Oct 29, 2012 12:42 pm
Get a surface drive prop
Mon Oct 29, 2012 12:49 pm
:/ and I think the 10x8 I have is a longtail... its the one from hill marine any way to tell if its a true sd prop? Thanks for the input guys!
Mon Oct 29, 2012 1:05 pm
Google that shit, props look totally different
Mon Oct 29, 2012 1:15 pm
1436 Lowe
Mon Oct 29, 2012 1:16 pm
Mon Oct 29, 2012 2:58 pm
So like a 9x9 will put me In good standings?
Mon Oct 29, 2012 4:04 pm
Mon Oct 29, 2012 5:40 pm
Im running a tricked out 13 hp. 36top 44 bott = 1.22
Dixie Mud Motor 1442 alumacraft.
9x9 max 24 mph alone. Slips with load
9x10 custom re-pitch & cup same top speed but slips bad under load
10x6 is the best prop for my boat under all loads. 6% slip. rpms below 3700.
good luck.
Mon Oct 29, 2012 6:46 pm
24 mph? That's outstanding! I'm close to the same gears. I have 32top and 44 bottom. But as mentioned nowhere near those speeds!
Mon Oct 29, 2012 6:54 pm
Good info - are they SD props or LT ???
24mph is awesome with only a 13hp motor !
He said above he had a 10x8 - do you think he could turn
it with his lower gearing ???
Mon Oct 29, 2012 6:58 pm
I think my 10x8 is a lt prop.... and my 9x6 prop came off a lt. What rpms should my motor be seeing? I saw a calculation a while back whatever your rpms on motor were you could figure out what the prop was spinning. Don't remember what it was though. I really appreciate the info guys
Mon Oct 29, 2012 7:23 pm
I would think 3800-4300 rpm that's what all my motors ran
Mon Oct 29, 2012 7:58 pm
If thats the case it should have no problem spinning the prop I think the prop according to mudbuddys site is rated for 3800-4000.... unless the prop can be overspun? What's that about?
Mon Oct 29, 2012 8:08 pm
Mon Oct 29, 2012 8:22 pm
Theoretically speaking.... damn and I'm half of that. I guess ima have to wait on thay damn tach and go from there thanks gigafowl!
Mon Oct 29, 2012 8:37 pm
When I hook my tach up do I run that out of the water? Or do I get a reading in the water?
Thu Nov 01, 2012 7:51 pm
Thu Nov 01, 2012 9:21 pm
Will I be able to tell out of water if ill be able to turn a 10x8?
Fri Nov 02, 2012 8:58 am
I don't think so. He's saying to make sure your motor is running max rpms out of water. To make sure your gov is set right.
Fri Nov 02, 2012 9:42 am
Ok and the norm would be 3800-4200? And if not remove the governor?
Fri Nov 02, 2012 10:03 am
Run ur motor on the trailer and see what u can turn up.
If u don't turn up 4200 that's part of ur problem, adjust so that u do.
Then launch ur rig and see what u r turning up. Wot
U wanna b turning up bout 38 39
If ur not turning that high ur not turning ur prop
If u over turning u need a bigger prop r pitch
The goal u r trying to achieve is turning the biggest prop ur motor can turn
There for pushing more water
Running faster
Sat Nov 03, 2012 9:24 pm
Thanks makes sence now.
Sat Nov 03, 2012 9:39 pm
Ok got all my throttle figured out. Removed the governor and hooked up the tach, 5200 comftorable and it could go higher but prolly not safe for motor. What y'all figure it would turn in the water?
Mon Nov 05, 2012 7:19 pm
5200? And you're comfortable with that?
Mon Nov 05, 2012 11:54 pm
Not particularly, thats what I got it to before. I shut it off. Question I was trying to get to was is it enough to spin a 10x8
Tue Nov 06, 2012 5:25 am
Did you understand that the governor setting was to LIMIT rpms
to NO MORE THAN 4200 rpm ???
This protects the motor when it pops out of water unexpectedly....
Sometimes when it is set too LOW it limits at below 3500 - and that
is why guys told you to check your out of water rpms.... You need
to get that thing set right or you will loose the motor to excess rpms
like the 5200 rpms you just turned....
When you are properly setup with the right prop you will be turning
between 3500 and 4000 - but no one will be able to tell you anything
from what you have posted thus far too many variables....
Now that you have a tach - get out and water test it to find that
proper setup - you can post up info with rpms and speeds on different
props and then get more input....
Tue Nov 06, 2012 7:37 am
Thanks giga ill put it back in amd see where I'm at and adjust accordingly.
Tue Nov 06, 2012 9:37 am
You better swap you life jacket out for a Kevlar vest to help protect you when the fly wheel comes apart. 5200 is WAY TOO HIGH for that motor. Running the motor out of the water won't do you any good. All of you tuning needs to be done in the water.
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Tue Nov 06, 2012 12:27 pm
Ok I got it set on the bench a lil over 4200. But if I meed more in the water I can get it. Is this safer?
Tue Nov 06, 2012 4:25 pm
U don't want more than that, ur motor will blow.
Ur motor is now set right. At this point everything else is prop. Put it n the water wot and see what Rpms u turn up.
Tue Nov 06, 2012 10:35 pm
Users browsing this forum: No registered users and 181 guests
