It is currently Tue Jul 29, 2025 12:48 am
Reply to topic  [ 26 posts ]
 Hard hat light bulb
Post Hard hat light bulb
Where can I get a replacement bulb for my hard hat light?
Gator Trax 1850HD/ MB 6000
Thu Dec 20, 2012 4:47 am
Post Re: Hard hat light bulb
I ordered mine at O'Reillys auto parts. I think it is GE #4508?
Thu Dec 20, 2012 5:21 am
This is the one I use, but there are a bunch out there to choose from
http://www.grainger.com/Grainger/GE-LIG ... ight-6VK26
1944 skiff with 35 GTR
Thu Dec 20, 2012 5:30 am
I dont remember the numbers on mine but just look at the back of the bulb. Locally where I bought my set up a replacement was 32 bucks. Half of the price of the light set up. I got 3 off of the internet with shipping for 32 bucks.
Thu Dec 20, 2012 6:59 am
Yall need to get away from that old time junk!
Thu Dec 20, 2012 5:48 pm
And get what?
Thu Dec 20, 2012 6:14 pm
www/aircraftspruce.com
Were $18.00 when I last bought one
Fri Dec 21, 2012 2:13 am
Go to napa and ask for a # 4509 bulb it's 13v 100 watt aircraft bulb. Gonna cost about $20.
1946 Charles Leonard Bateaux Stage 2 GTR
Fri Dec 21, 2012 2:25 am
HuntSmart.com has there seal beam replacement bulb for $19.99 an it shines a better spot then the aircraft lights
Fri Dec 21, 2012 8:40 am
Pierre Part store keeps plenty of them in stock
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Fri Dec 21, 2012 8:59 am
Fri Dec 21, 2012 9:41 am
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Wed Feb 20, 2013 10:12 am
Wed Feb 20, 2013 10:17 am
Wed Feb 20, 2013 11:03 am
Wed Feb 20, 2013 11:10 am
Wed Feb 20, 2013 11:12 am
Wed Feb 20, 2013 11:16 am
Wed Feb 20, 2013 11:30 am
Some bulbs are more sensitive to voltage and, more importantly, current changes. When your battery gets low (putting out less than 12v) it takes more current to do the same job. More current creates more heat, more heat creates more failures... most any of them will last a LONG time with proper input voltage. Some may handle the lower voltage/higher current better than others...
My lights came from napa, believe they are ge. Ive never had one fail, but I usually only use them to get where I'm going and I keep my batteries fully charged. If you are using them all night for frogging and what not, you may look into running two or more batteries in parallel. Assuming both batts are the same, two would last twice as long before the voltage starts to drop. Bulbs will last a lot longer with a good power supply...
Wed Feb 20, 2013 11:38 am
I dont have any problems with mine either I throw them down in the boat I've dropped in water and still never have problems with the bulbs but I use the Wagner ones not the GE ones
Wed Feb 20, 2013 11:44 am
I do a good bit of frogging and run mine all night and have drained batteries doing it. No clue on hours but it's way more than 20-30
Wed Feb 20, 2013 11:45 am
I watched one withstand two back to back full blown wwf style body slams from Sammyc one night
Wed Feb 20, 2013 11:48 am
Wed Feb 20, 2013 11:54 am
CB, I hook mine up to my 12v on my boat hooked to my cranking battery it stays charged with the motor running , when you put hard hours on cheap shit they don't last.
Wed Feb 20, 2013 1:50 pm
Wed Feb 20, 2013 2:46 pm
That light had it coming!!!!
Wed Feb 20, 2013 8:00 pm
Users browsing this forum: No registered users and 102 guests
