Hard hat light bulb
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=35538
Author:  h2ofowlhunter [ Thu Dec 20, 2012 4:47 am ]
Post subject:  Hard hat light bulb
Where can I get a replacement bulb for my hard hat light?
Author:  Cubman [ Thu Dec 20, 2012 5:21 am ]
Post subject:  Re: Hard hat light bulb
I ordered mine at O'Reillys auto parts. I think it is GE #4508?
Author:  Nate [ Thu Dec 20, 2012 5:30 am ]
This is the one I use, but there are a bunch out there to choose from
http://www.grainger.com/Grainger/GE-LIG ... ight-6VK26
Author:  naj [ Thu Dec 20, 2012 6:59 am ]
I dont remember the numbers on mine but just look at the back of the bulb. Locally where I bought my set up a replacement was 32 bucks. Half of the price of the light set up. I got 3 off of the internet with shipping for 32 bucks.
Author:  JIMMY W [ Thu Dec 20, 2012 5:48 pm ]
Yall need to get away from that old time junk!
Author:  Beadlejuicejr [ Thu Dec 20, 2012 6:14 pm ]
And get what?
Author:  Mike W. [ Fri Dec 21, 2012 2:13 am ]
www/aircraftspruce.com
Were $18.00 when I last bought one
Author:  dcboy [ Fri Dec 21, 2012 2:25 am ]
Go to napa and ask for a # 4509 bulb it's 13v 100 watt aircraft bulb. Gonna cost about $20.
Author:  deadcypress [ Fri Dec 21, 2012 8:40 am ]
HuntSmart.com has there seal beam replacement bulb for $19.99 an it shines a better spot then the aircraft lights
Author:  latravcha [ Fri Dec 21, 2012 8:59 am ]
Pierre Part store keeps plenty of them in stock
Author:  naj [ Fri Dec 21, 2012 9:41 am ]
Author:  Bayoublackhunter [ Wed Feb 20, 2013 10:12 am ]
Author:  tchauvin [ Wed Feb 20, 2013 10:17 am ]
Author:  Bayoublackhunter [ Wed Feb 20, 2013 11:03 am ]
Author:  tchauvin [ Wed Feb 20, 2013 11:10 am ]
Author:  dfou [ Wed Feb 20, 2013 11:12 am ]
Author:  tchauvin [ Wed Feb 20, 2013 11:16 am ]
Author:  Bayoublackhunter [ Wed Feb 20, 2013 11:30 am ]
Author:  cb5331 [ Wed Feb 20, 2013 11:38 am ]
Some bulbs are more sensitive to voltage and, more importantly, current changes. When your battery gets low (putting out less than 12v) it takes more current to do the same job. More current creates more heat, more heat creates more failures... most any of them will last a LONG time with proper input voltage. Some may handle the lower voltage/higher current better than others...
My lights came from napa, believe they are ge. Ive never had one fail, but I usually only use them to get where I'm going and I keep my batteries fully charged. If you are using them all night for frogging and what not, you may look into running two or more batteries in parallel. Assuming both batts are the same, two would last twice as long before the voltage starts to drop. Bulbs will last a lot longer with a good power supply...
Author:  AKA Freshwaterkilla [ Wed Feb 20, 2013 11:44 am ]
I dont have any problems with mine either I throw them down in the boat I've dropped in water and still never have problems with the bulbs but I use the Wagner ones not the GE ones
Author:  dfou [ Wed Feb 20, 2013 11:45 am ]
I do a good bit of frogging and run mine all night and have drained batteries doing it. No clue on hours but it's way more than 20-30
Author:  dfou [ Wed Feb 20, 2013 11:48 am ]
I watched one withstand two back to back full blown wwf style body slams from Sammyc one night
Author:  AKA Freshwaterkilla [ Wed Feb 20, 2013 11:54 am ]
Author:  Bayoublackhunter [ Wed Feb 20, 2013 1:50 pm ]
CB, I hook mine up to my 12v on my boat hooked to my cranking battery it stays charged with the motor running , when you put hard hours on cheap shit they don't last.
Author:  cb5331 [ Wed Feb 20, 2013 2:46 pm ]
Author:  SammyC [ Wed Feb 20, 2013 8:00 pm ]
That light had it coming!!!!
