17x54 GTB outboard size
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=36047
Page 1 of 2
Author:  TDUET [ Sat Jan 05, 2013 6:07 pm ]
Post subject:  17x54 GTB outboard size
Anyone use a outboard after duck season to fish? Thinking I would like to go his route to save wear and tear on the GTR..
Author:  TX Aggie '06 [ Sat Jan 05, 2013 6:27 pm ]
Post subject:  Re: 17x54 GTB outboard size
Buddy has a 90 Yamaha on his 1754 G3, I'm sure something similar would be fine.
Sent from my MB865 using Tapatalk 2
Author:  krogers [ Sat Jan 05, 2013 7:38 pm ]
Author:  Bigdeck20 [ Sat Jan 05, 2013 7:51 pm ]
Buddy of mine has a 90 Yamaha on a 17 excel and it will haul ass! But bounces a lot
Author:  msm8281 [ Sat Jan 05, 2013 7:57 pm ]
Put a 60 on it.
Author:  TDUET [ Sat Jan 05, 2013 8:30 pm ]
60hp is exactly what I was thinking
Author:  ak [ Sun Jan 06, 2013 2:48 am ]
Even a 40 would get you good
Author:  cupped up [ Sun Jan 06, 2013 8:36 am ]
Slap a 90 on it with a jack plate so you can eliminate the bounce and run prolly mid-upper 40s
Author:  TDUET [ Tue Jan 08, 2013 2:54 pm ]
Nexty question will prolly spark the same battle as of GTR/Prodrive but what brand yall running?
Author:  KJH [ Tue Jan 08, 2013 4:02 pm ]
I took the 35GTR off my last 1754 excel and put on a 60hp for a trip to Canada where I needed to run 20+ miles one way. It ran fine and pushed a heavy load. It turnd differently with the flat bottom and bounced if I turn sharper. I put the surface drive back on later that fall.
I wouldn't hesitate to do it again.
Author:  krogers [ Tue Jan 08, 2013 5:11 pm ]
Author:  TDUET [ Fri Jan 11, 2013 10:40 am ]
Thanks for the info guys.... im now looking for a 60hp outboard to buy... Let me know if you see something that comes up for sale
Author:  TDUET [ Sat Jan 26, 2013 8:39 am ]
I got a 2010 50 Merc yesterday 4 stroke. I wasnt to happy with the maiden voyage. The boat barley got out of its own way and on step. Top speed was around 28-29 mph. I know props size and pitch are everything when it comes to outboards but without having a tack im shooting in the dark.. I was really hoping to get HIGH 30's loaded down with this set up. I might have hoped for to much. Any ideas on prop size for this set up? I took a mesurment and I got 10" by 15 pitch. 15p is stamped on the prop. This is the prop that came with the motor. If I cant get it right ill just sell being I got it for a great price and its a super clean motor
Author:  cupped up [ Sat Jan 26, 2013 8:48 am ]
Author:  TDUET [ Sat Jan 26, 2013 8:51 am ]
Author:  cupped up [ Sat Jan 26, 2013 8:56 am ]
That's a fact! I had a 16x60 welded bateau with 24" sides with a 75 evinrude at one time and I was lucky to get anything over 35 in it, and that was with a 17p prop. That GT boat is more boat to push than you would think!
Author:  garrettpearce [ Sat Jan 26, 2013 9:11 am ]
4 stroke. That's why. throw a 70 yammy 4 stroke and it'll run. I'm a merc 2 stroke man but yammy four stroke
Author:  TDUET [ Sat Jan 26, 2013 9:20 am ]
Ill change the prop and pitch first and see what I can get from it.
Author:  MNGunner [ Sat Jan 26, 2013 9:22 am ]
Author:  TDUET [ Sat Jan 26, 2013 9:29 am ]
Believe me I'm really surprised reguardless of 4 or 2 stroke
Author:  T-Bubba [ Sat Jan 26, 2013 9:29 am ]
should have got a 115 pro xs optimax
Author:  TDUET [ Sat Jan 26, 2013 4:39 pm ]
Ran a 10.6 with less pitch today and nothing changed! The motor feels like it wants more at times. You can almost feel it take off for a sec but fall back off. Same speeds around 26-27mph. Something gotta be wrong with the motor. A guy in 25hp tiller passed me up in the canal!! Lol. Fuck my life!
Author:  MNGunner [ Sat Jan 26, 2013 5:15 pm ]
My fishing boat is a 17' deep V Lund with a 50 HP Merc 4-stroke tiller. It came with a 13 pitch prop and I went down to 12 (4 blade stainless) for better hole shot went loaded with three guys. BUT, that boat is 1,000 lbs dry, has a 27 gal fuel tank, 3 batteries, two large live wells, two trolling motors. Top speed is about 29mph (can hit 30 at times). I lost just a little on top speed going down to a 12 from a 13.
With your rig (should be much lighter), and the fact that you have a flat bottom that get's on plane faster, I would think you'd want at least a 13 pitch or higher.
With your 10.6 prop, are you instantley on plane?? Does the motor seem to rev high? Sounds like it's pitched way too low to me...
Author:  Phathead [ Sat Jan 26, 2013 5:22 pm ]
I think you can get a little more out of this motor by removing a small air restrictor at the intake. I believe I remember seeing a post about this on another site about 2 or 3 years ago. Something about the ecu automatically sensing the increased airflow and recalibrating to a higher hp level--maybe 60ish hp. Might want to check into this before going about it blindly.
Author:  TDUET [ Sat Jan 26, 2013 6:12 pm ]
Talked to Hoyt today he said ez'ly I should be pushing 40. Im goig to raise the motor to the highest setting and run both props and see
Author:  TDUET [ Sat Jan 26, 2013 6:13 pm ]
Author:  JIMMY W [ Sat Jan 26, 2013 6:45 pm ]
Author:  MNGunner [ Sun Jan 27, 2013 10:41 am ]
Author:  bayouboy263 [ Sun Jan 27, 2013 11:33 am ]
Baggy's Propeller Repair
(985) 868-0103
Baggy will tell you what's up.
Author:  TDUET [ Sun Jan 27, 2013 12:55 pm ]
Tried again today after we raised the motor to the highest setting and ran both props again. Still 25-28. FML. Calling baggy and bringing the motor back where I bought it.
Author:  SwampSlut [ Sun Jan 27, 2013 1:03 pm ]
do you have a 20" shaft ob and a 20" transom??
Author:  TDUET [ Sun Jan 27, 2013 1:15 pm ]
21" tran. 20" shaft
Author:  TDUET [ Sun Jan 27, 2013 1:16 pm ]
Author:  Cumminsdiesel69 [ Sun Jan 27, 2013 4:05 pm ]
x2 that man knows props and will get it right if the prop is the problem!
Author:  T-Bubba [ Sun Jan 27, 2013 4:21 pm ]
baggy knows his props
i went from a 4 blade powertech 15pt to a 3 blade turbo 17pt... like a totally different boat
Author:  bayouboy263 [ Tue Jan 29, 2013 7:37 am ]
Author:  WestEndAngler [ Tue Jan 29, 2013 7:59 am ]
What RPM are you running at your top speed TDUET?
Author:  TDUET [ Tue Jan 29, 2013 1:43 pm ]
Easy quick fix! 3 cyl is blown in the motor. Going get my $$ back and going get a new one! Lol
Author:  270Handiman [ Tue Jan 29, 2013 1:58 pm ]
That would do it, lol.
Author:  msm8281 [ Tue Jan 29, 2013 6:18 pm ]
Page 1 of 2 All times are UTC - 6 hours
