h2ofowlhunter
Joined: Sun Oct 09, 2011 8:57 am Posts: 72 Location: Buffalo, Tx
 Hard hat light bulb
Where can I get a replacement bulb for my hard hat light?
_________________ Gator Trax 1850HD/ MB 6000
Thu Dec 20, 2012 4:47 am |
Cubman
Joined: Sun May 16, 2010 8:53 pm Posts: 254 Location: East TN
 Re: Hard hat light bulb
I ordered mine at O'Reillys auto parts. I think it is GE #4508?
Thu Dec 20, 2012 5:21 am |
Nate
Joined: Sun Jun 17, 2012 1:30 pm Posts: 425 Location: Houma, LA
This is the one I use, but there are a bunch out there to choose from http://www.grainger.com/Grainger/GE-LIG ... ight-6VK26
_________________ 1944 skiff with 35 GTR
Thu Dec 20, 2012 5:30 am |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
I dont remember the numbers on mine but just look at the back of the bulb. Locally where I bought my set up a replacement was 32 bucks. Half of the price of the light set up. I got 3 off of the internet with shipping for 32 bucks.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Thu Dec 20, 2012 6:59 am |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Yall need to get away from that old time junk!
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
Thu Dec 20, 2012 5:48 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
And get what?
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Thu Dec 20, 2012 6:14 pm |
Mike W.
Joined: Thu Jan 15, 2009 2:26 pm Posts: 146 Location: Vanceboro, NC
www/aircraftspruce.com
Were $18.00 when I last bought one
_________________ "They call us civilized, cause we're easy to sneak up on!"
Fri Dec 21, 2012 2:13 am |
dcboy
Go to napa and ask for a # 4509 bulb it's 13v 100 watt aircraft bulb. Gonna cost about $20.
_________________ 1946 Charles Leonard Bateaux Stage 2 GTR
Fri Dec 21, 2012 2:25 am |
deadcypress
Joined: Tue Jan 13, 2009 7:26 pm Posts: 41 Location: Cypremort Point ,La.
HuntSmart.com has there seal beam replacement bulb for $19.99 an it shines a better spot then the aircraft lights
Fri Dec 21, 2012 8:40 am |
latravcha
Pierre Part store keeps plenty of them in stock
_________________ Aucoin 20X48 36pd Lock your wife and your dog in the garage for an hour. Then open it and see who's happy to see you.
Fri Dec 21, 2012 8:59 am |
naj
Fri Dec 21, 2012 9:41 am |
Bayoublackhunter
Joined: Sat Oct 02, 2010 4:55 pm Posts: 1192 Location: BAYOU BLACK
_________________ 35gtr on a 1854 Deep South Custom 1436 flat pushed by a 16 GDLT
Wed Feb 20, 2013 10:12 am |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
Wed Feb 20, 2013 10:17 am |
Bayoublackhunter
Wed Feb 20, 2013 11:03 am |
tchauvin
Wed Feb 20, 2013 11:10 am |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
Wed Feb 20, 2013 11:12 am |
tchauvin
Wed Feb 20, 2013 11:16 am |
Bayoublackhunter
Wed Feb 20, 2013 11:30 am |
cb5331
Some bulbs are more sensitive to voltage and, more importantly, current changes. When your battery gets low (putting out less than 12v) it takes more current to do the same job. More current creates more heat, more heat creates more failures... most any of them will last a LONG time with proper input voltage. Some may handle the lower voltage/higher current better than others...
My lights came from napa, believe they are ge. Ive never had one fail, but I usually only use them to get where I'm going and I keep my batteries fully charged. If you are using them all night for frogging and what not, you may look into running two or more batteries in parallel. Assuming both batts are the same, two would last twice as long before the voltage starts to drop. Bulbs will last a lot longer with a good power supply...
Wed Feb 20, 2013 11:38 am |
AKA Freshwaterkilla
I dont have any problems with mine either I throw them down in the boat I've dropped in water and still never have problems with the bulbs but I use the Wagner ones not the GE ones
Wed Feb 20, 2013 11:44 am |
dfou
I do a good bit of frogging and run mine all night and have drained batteries doing it. No clue on hours but it's way more than 20-30
Wed Feb 20, 2013 11:45 am |
dfou
I watched one withstand two back to back full blown wwf style body slams from Sammyc one night
Wed Feb 20, 2013 11:48 am |
AKA Freshwaterkilla
Wed Feb 20, 2013 11:54 am |
Bayoublackhunter
CB, I hook mine up to my 12v on my boat hooked to my cranking battery it stays charged with the motor running , when you put hard hours on cheap shit they don't last.
Wed Feb 20, 2013 1:50 pm |
cb5331
Wed Feb 20, 2013 2:46 pm |
SammyC
Joined: Thu May 26, 2011 8:06 pm Posts: 413 Location: P-Ville, La
That light had it coming!!!!
Wed Feb 20, 2013 8:00 pm |
