It is currently Sun Jul 20, 2025 3:21 pm
Reply to topic  [ 8 posts ]
 Need advice on my rig
Post Need advice on my rig
I have a 1548 weldbilt and wondering what's going to work out best on it! I already have tilt and trim on the boat. This will be my first mud motor and can't have anything bigger then a 35 hp. What would you guess recommend?
Thanks:H20GASM
Sun Feb 24, 2013 9:13 am
Post Re: Need advice on my rig
H20...Quick answer, the new GTR 25. However, my advice is to do a lot more research before you jump into this. That boat is not built for any of these motors. The aluminum is .100 and the transom is not what it should be. Most builders use thicker aluminum for their rigs. Don't be in a hurry with this. Research this site and you will learn a lot. If you plan on doing things in that boat that you cant do with a normal outboard, you will tear that boat to peices very quickly.
Wed Feb 27, 2013 10:13 am
You've already got tilt and trim on the boat? Like the jack plate style cmc trim? If that's the case I'm pretty sure you can take that off and throw it away if you're putting a mud motor on the boat, it prolly ain't gonna work.
Wed Feb 27, 2013 10:40 am
GTR 25
1854 GTB Extreme 35GTR
Wed Feb 27, 2013 12:09 pm
Wed Feb 27, 2013 1:19 pm
Thanks for ya advice! May look into a new boat then also!
Wed Feb 27, 2013 8:18 pm
I been running a 35 gator tail with stage 1 on a 15/48 sea ark whole boat is .100 . I have jumped plenty of levees and hit a lot of logs and boat holds up greAt ,Before I had gator tai I ran a 27 Prodrive for 6 year with no boat problems unless you are ramming your boat into trees you will be just fine running a big motor on your boat
17/54 gator tail extreme with a stage 2 gator tail strapped on the back
viewtopic.php?f=5&t=43412
Thu Feb 28, 2013 10:22 pm
http://youtu.be/JxChbwQNCR4
This boat is .100 gauge an that's a 35 with stage 1 , that is just one video I do this stuff all the time , boat is 7 years old with no problems , even if it does ever crack sea ark has life time warranty on hull, so for all you ppl day they don't last , yes they do
Sun Mar 03, 2013 6:54 pm
Users browsing this forum: No registered users and 98 guests
