Hydroturf problem
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=38655
Author:  nasty [ Tue Mar 12, 2013 8:40 pm ]
Post subject:  Hydroturf problem
Putting hydroturf down and using the 3m 90 hi- strength spray adhesive, then going around with contact cement around edges. I'm having a problem with it bubbling in the middle, am I not letting the spray adhesive tack long enough? And in these spots what can I do to fix?
Author:  nasty [ Tue Mar 12, 2013 8:41 pm ]
Post subject:  Re: Hydroturf problem
Also what can I put to keep seams together and tight?
Author:  Team Camo [ Tue Mar 12, 2013 9:24 pm ]
It should be dry, not tacky, when you lay it down.
Author:  cb5331 [ Tue Mar 12, 2013 9:26 pm ]
You have to put it on both surfaces, wait till it dries, then once you put it down, it ain't coming back up.
Author:  nasty [ Tue Mar 12, 2013 9:30 pm ]
I did put it on both, guess I'm not waiting long enough for it to dry
Author:  med [ Tue Mar 12, 2013 9:32 pm ]
Weldwood contact cement in the green can.
Sent from my DROIDX using Tapatalk 2
Author:  The Shafer [ Tue Mar 12, 2013 9:41 pm ]
With it bubbling up take your razor and make a small cut in the middle of the bubble. Then work the outside of the bubble to the inside pushing it down. Once it's all pushed down you won't be able to see the cut
Author:  OwenDickeson [ Tue Mar 12, 2013 9:49 pm ]
Use the right amount of dry time. The adhesive is still off-gassing.
Author:  med [ Tue Mar 12, 2013 10:00 pm ]
Author:  Shooter007 [ Fri Mar 15, 2013 12:20 pm ]
Author:  nasty [ Sat Mar 16, 2013 5:16 am ]
I did.
