nasty
 Hydroturf problem
Putting hydroturf down and using the 3m 90 hi- strength spray adhesive, then going around with contact cement around edges. I'm having a problem with it bubbling in the middle, am I not letting the spray adhesive tack long enough? And in these spots what can I do to fix?
Tue Mar 12, 2013 8:40 pm |
nasty
 Re: Hydroturf problem
Also what can I put to keep seams together and tight?
Tue Mar 12, 2013 8:41 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
It should be dry, not tacky, when you lay it down.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Tue Mar 12, 2013 9:24 pm |
cb5331
You have to put it on both surfaces, wait till it dries, then once you put it down, it ain't coming back up.
Tue Mar 12, 2013 9:26 pm |
nasty
I did put it on both, guess I'm not waiting long enough for it to dry
Tue Mar 12, 2013 9:30 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Weldwood contact cement in the green can.
Sent from my DROIDX using Tapatalk 2
_________________ 1850 & 36pd
Tue Mar 12, 2013 9:32 pm |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
With it bubbling up take your razor and make a small cut in the middle of the bubble. Then work the outside of the bubble to the inside pushing it down. Once it's all pushed down you won't be able to see the cut
_________________ WC 1848 Bateau w/ 36 PD FPR
Tue Mar 12, 2013 9:41 pm |
OwenDickeson
Use the right amount of dry time. The adhesive is still off-gassing.
Tue Mar 12, 2013 9:49 pm |
med
Tue Mar 12, 2013 10:00 pm |
Shooter007
Joined: Fri May 08, 2009 11:21 am Posts: 100 Location: Wisconsin
_________________ 2011 3 Man Gator Hide 10' MB 7000 Zoom, Zoom
Fri Mar 15, 2013 12:20 pm |
nasty
I did.
Sat Mar 16, 2013 5:16 am |
