It is currently Sun Jul 20, 2025 4:10 pm
Reply to topic  [ 22 posts ]
 Pro drive idle rpm?
Post Pro drive idle rpm?
What is the typical idle rpm for a 36hp pro drive? Mine wants to stall out when engaging the clutch while in the water and I'm wondering if I should bump up my idle speed.
Wed Apr 03, 2013 5:27 pm
Post Re: Pro drive idle rpm?
1200-1400
Wed Apr 03, 2013 5:32 pm
1-2 then break down
Wed Apr 03, 2013 5:33 pm
If that dont work, and it's new! Ur valves are probably leaking...
Wed Apr 03, 2013 5:41 pm
Get your valves checked I have a new motor and had the Same prob but for the longest time I had an old long tail it was a feel you get from running it to know the throttle and clutch to not kill it
Wed Apr 03, 2013 5:49 pm
Mines idleing anywhere from 700-900 and sounds fine, a little lopey. I didn't know what the correct idle speed was. Engine only has 75 hrs.
Wed Apr 03, 2013 6:17 pm
Thu Apr 04, 2013 7:23 am
set it at 1200... if it still stumbles get the valves checked
I gave up mud motors
Thu Apr 04, 2013 7:26 am
1200 isn't too high? It won't cause damage to the clutch to engage at that speed?
Thu Apr 04, 2013 9:55 am
1200 is fine. Lawnmowers are running 3700RPM when you kick in the clutch on them and it is the same style clutch.
Thu Apr 04, 2013 10:05 am
I set it to 1150-1170. It seems much better. Like I said it was set to idle below 1000. I'll run it and see what happens, I bet that was the only problem.
Thu Apr 04, 2013 10:10 am
I see people engage the clutch a wot :shock:
2013 1846 Gator Series w/ 35 GTR Hoyt's heads and gutted stock exhaust
Thu Apr 04, 2013 10:15 am
WC 1848 Bateau w/ 36 PD FPR
Thu Apr 04, 2013 10:21 am
Thu Apr 04, 2013 11:29 am
Thu Apr 04, 2013 11:59 am
Thu Apr 04, 2013 12:15 pm
Damn bayou boy how much was that repair?
Thu Apr 04, 2013 1:24 pm
Weld it back, sand and let it roll!
Thu Apr 04, 2013 1:28 pm
Thu Apr 04, 2013 1:29 pm
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Thu Apr 04, 2013 3:21 pm
Seems to me that this fellow can break a anvil with a rubber mallet!
Thu Apr 04, 2013 3:52 pm
Thu Apr 04, 2013 4:05 pm
Users browsing this forum: No registered users and 132 guests
