GTR Reverse https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=3956 |
Author: | Ace [ Sun Aug 16, 2009 8:44 am ] |
Post subject: | GTR Reverse |
OK so we went frogging Fri. nite, noticed reverse lever was really low. Suspected low fluid. Small town near camp, could only find DOT 3 brake fluid. Filled reservoir with DOT 3, reverse lever came back up, worked fine all nite. What damage have I done with the DOT 3? Should I flush the system and replace with DOT5? What should I use to flush if so? |
Author: | shallow water master [ Sun Aug 16, 2009 9:31 am ] |
Post subject: | Re: GTR Reverse |
i dont know what kind of damage u did if any . u can flush it with new fluid |
Author: | dog walker [ Sun Aug 16, 2009 12:52 pm ] |
Author: | quackconsumer [ Sun Aug 16, 2009 1:51 pm ] |
DOT 3, DOT 5, Does it really make a difference???? |
Author: | Ace [ Mon Aug 17, 2009 9:49 am ] |
OK, so to close up this post. Called Hoyt this am and he said it most likely had DOT3 from GT when I bought it. He tells me that they will most likely be changing the manual from DOT5 to 3. Shouldn't be a problem, but I did see on the www where you can't mix the 5 with the 3. Causes some kind of gelling problem. Anyway, I didn't do any damage to my Reverse ![]() |
Author: | shallow water master [ Mon Aug 17, 2009 9:50 pm ] |
kool good deal |
Author: | grrifles [ Tue Aug 18, 2009 8:08 am ] |
If I remeber right the only difference is temp rating between dot 3 and dot 5. |
