It is currently Sun Jul 20, 2025 7:22 am
Reply to topic  [ 22 posts ]
 Fuel/water seperator?
Post Fuel/water seperator?
Do any of you guys use a fuel/water seperate? I'm curious if the stock fuel pump can handle pulling gas through another filter.
Thu May 09, 2013 12:39 pm
Post Re: Fuel/water seperator?
yes/ all day long :D
- Mark Twain
Thu May 09, 2013 12:44 pm
get one
GatorHide - MB
Thu May 09, 2013 12:51 pm
majority of people have one. its cheap insurance to protect your from paddling your ass back when cylinder fills up with water
Thu May 09, 2013 1:17 pm
Have had it on all my rigs!!!!
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
1854 GTB Extreme 35GTR
Thu May 09, 2013 1:36 pm
Mine is mounted in front of boat close to the gas tank
1844 DFOU CUSTOM, PRODRIVE 36 EFI
viewtopic.php?t=38177
Thu May 09, 2013 3:14 pm
Thu May 09, 2013 4:51 pm
Mine is under huntdeck :D
Thu May 09, 2013 4:55 pm
Thu May 09, 2013 4:59 pm
Thu May 09, 2013 6:00 pm
Fri May 10, 2013 9:52 am
I don't use a primer. I installed everything with the thought if there is a problem I will add a primer. Fuel pump filled canister and pulls it no problem.
Fri May 10, 2013 10:53 am
Mine closer to the primer in the back of the boat with the fuel tank at the front. Works fine. What's the reason for having it up front with the tank?
35 GTR with marshmellow on 1854 Gator Tail Boat.
Fri May 10, 2013 8:08 pm
If there is water in fuel and the separator is in the back... If temps drop below freezing I have 18' of fuel line to thaw out vs. less than a foot.
Fri May 10, 2013 8:13 pm
Fri May 10, 2013 9:18 pm
And how often y'all change the filter, assuming running every month, usual weekend huntn/fishn trips?
Fri May 10, 2013 10:04 pm
GatorHide - MB
Fri May 10, 2013 10:23 pm
Fri May 10, 2013 11:38 pm
Yes. Racor filters on everything that floats.
MoMarsh Fatboy/2 Honda
Sat May 11, 2013 4:43 am
Sat May 11, 2013 4:53 am
Sat May 11, 2013 7:55 am
Honestly I've never thought about putting it up front. I like it on the transom, easy access. That's where I'll keep it.
Sat May 11, 2013 8:44 am
Users browsing this forum: No registered users and 77 guests
