It is currently Tue Aug 05, 2025 5:16 am
[ 7 posts ] |
Mudgun
Joined: Wed Jan 14, 2009 12:24 pm Posts: 746 Location: Here Be Rocks VA
 Un Locking Loctite..
I got a PM about this and figured I'd share it since a lot of people use Loctite or equivalent.
Red loctite (271 is commonly used) is permanent. It is not designed to come loose. However, if you need to get it loose here's how it's done.
Loctite 271 is rated to 300°f and it takes about 100°f more to cause it to fail. Using my calculator that's 400°f.
One guy holds the torch and gets the appratus to 400°f while the other guy works the wrench. Do not use your wife's oven mitts, she will get pissed. Keep the heat on the spot. Don't let it cool.
The initial "snap" or loosening will occur at about 230-250 in/lbs and you will think you are home free. You aren't. Keeping the heat on, you will think you are cross threading the fastener. You're not. It will take about 350 in/lbs to get past where the Loctite is. That's how it is designed. It's supposed to have a higher fail point than the initial fail point.
Anyway...if you got it stuck get the torch and keep it on there.
_________________ 1660 Rhino High-Side with center console 90/65 Mercury 2 stroke Outboard jet pump Run shallow, run loud.
Tue Aug 25, 2009 9:48 am |
Mud Slinger
MMT Moderator
 Re: Un Locking Loctite..
use Mapp gas works faster  thats the red bottle
_________________ duck wacker
Tue Aug 25, 2009 5:11 pm |
coondik
Threadlocker is over-rated
Tue Aug 25, 2009 5:59 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
wow, that sounds very text book.
_________________ BUCK OFAMA
Tue Aug 25, 2009 6:23 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
_________________ Put yer face in the myrtles.
Tue Aug 25, 2009 6:24 pm |
etquackster
Joined: Tue Jan 13, 2009 8:47 pm Posts: 333 Location: tyler ,tx
red loctite is the devil.
_________________ boatless!!!!!!!!!
Tue Aug 25, 2009 6:47 pm |
LA OUTLAW
Joined: Mon Mar 02, 2009 9:25 pm Posts: 1096 Location: Morgan City
Yep it sure is da devil' ask basinhunter!!!
_________________ 1754 GT EXTREME 37EFI
Tue Aug 25, 2009 11:29 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 78 guests |
