clutch problem https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=40496 |
Author: | RoyBoy10 [ Tue May 07, 2013 12:21 pm ] |
Post subject: | clutch problem |
Went fishing all day yesterday and when I was coming in my clutch seemed like it disengaged while running on step.Stopped put it in neutral then back in forward and it went for ten feet then quit again. This time it wouldn't do anything. I checked wires and fuses and everything looks good. Where do I go from here? Its a 2011 gtr 35 Thanks |
Author: | msm8281 [ Tue May 07, 2013 1:12 pm ] |
Post subject: | Re: clutch problem |
Is the 25 amp fuse blown |
Author: | RoyBoy10 [ Tue May 07, 2013 1:20 pm ] |
Author: | msm8281 [ Tue May 07, 2013 1:23 pm ] |
Loose connection somewhere then |
Author: | DUCK HEARSE [ Tue May 07, 2013 1:33 pm ] |
Had same problem pull fuse out and clean connection had some corrsion in there. |
Author: | RoyBoy10 [ Tue May 07, 2013 2:52 pm ] |
cleaned the connections and still no power? |
Author: | Quackhead62 [ Tue May 07, 2013 3:06 pm ] |
could be a broken wire up stream of the fuse |
Author: | deadcypress [ Tue May 07, 2013 3:35 pm ] |
toggle switch |
Author: | SCSuperfly [ Tue May 07, 2013 4:31 pm ] |
Read through the two connections on the clutch itself. It's just a coil of wire. If you read anything it's good. If you read OL "open line" then the clutch itself is bad. Do you have 12 volts going to the clutch? |
Author: | Marshrat823 [ Tue May 07, 2013 6:26 pm ] |
I had the PTO switch go out on my prodrive. I don't know if your motor has that type also but it may be the switch. Warren |
Author: | Team Camo [ Wed May 08, 2013 8:28 pm ] |
If you can't get it figured out, bring it by & we'll get it going again. Clutch issue can be several different things. |
Author: | gmc [ Thu May 09, 2013 7:57 pm ] |
Ive had this happen about 4 times on my 2012 gtr and it was always a broken wire inside the control box |
