It is currently Sun Jul 20, 2025 10:33 am
Reply to topic  [ 12 posts ]
 clutch problem
 clutch problem
Went fishing all day yesterday and when I was coming in my clutch seemed like it disengaged while running on step.Stopped put it in neutral then back in forward and it went for ten feet then quit again. This time it wouldn't do anything. I checked wires and fuses and everything looks good. Where do I go from here? Its a 2011 gtr 35
Thanks
1754GT 35GTR
Tue May 07, 2013 12:21 pm
Post Re: clutch problem
Is the 25 amp fuse blown
Tue May 07, 2013 1:12 pm
1754GT 35GTR
Tue May 07, 2013 1:20 pm
Loose connection somewhere then
Tue May 07, 2013 1:23 pm
Had same problem pull fuse out and clean connection had some corrsion in there.
- Mark Twain
Tue May 07, 2013 1:33 pm
cleaned the connections and still no power?
1754GT 35GTR
Tue May 07, 2013 2:52 pm
could be a broken wire up stream of the fuse
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Tue May 07, 2013 3:06 pm
toggle switch
Tue May 07, 2013 3:35 pm
Read through the two connections on the clutch itself. It's just a coil of wire. If you read anything it's good. If you read OL "open line" then the clutch itself is bad. Do you have 12 volts going to the clutch?
Modded 36 PD draggin' around an 1848 PD boat backwards!
Tue May 07, 2013 4:31 pm
I had the PTO switch go out on my prodrive. I don't know if your motor has that type also but it may be the switch.
Warren
“Firearms are not frightening. Not a single one of my firearms has ever put on a pair of shoes, run down the street and killed somebody.”
Tue May 07, 2013 6:26 pm
Profile YIM
If you can't get it figured out, bring it by & we'll get it going again. Clutch issue can be several different things.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed May 08, 2013 8:28 pm
Ive had this happen about 4 times on my 2012 gtr and it was always a broken wire inside the control box
Thu May 09, 2013 7:57 pm
Users browsing this forum: No registered users and 110 guests
