2000 gph bilge pump https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=41178 |
Author: | renovator [ Tue May 28, 2013 7:04 pm ] |
Post subject: | 2000 gph bilge pump |
If your boat has this profile with a big engine, and you run deep water to get to shallow water. Then you should know why its needed ![]() |
Author: | Fletch [ Tue May 28, 2013 7:18 pm ] |
Post subject: | Re: 2000 gph bilge pump |
Wish I would have gotten bigger. I have the 500. |
Author: | renovator [ Tue May 28, 2013 7:23 pm ] |
Almost sunk twice with a 750. Now its 2000 and nothing less. |
Author: | Bigrich [ Tue May 28, 2013 7:26 pm ] |
I was gonna do that but I went with dual 1100's that way if one goes out I still have a back up |
Author: | renovator [ Tue May 28, 2013 7:34 pm ] |
Thought of that but I wanted something with a big impeller to help cut/pass grass and mud. |
Author: | Bigrich [ Tue May 28, 2013 7:45 pm ] |
Yeah that's a good idea for sure! My shit never seems to work right so always need a spare! |
Author: | renovator [ Tue May 28, 2013 7:49 pm ] |
Author: | Bigrich [ Tue May 28, 2013 8:08 pm ] |
Sticks would b my issue |
Author: | Bigrich [ Tue May 28, 2013 8:16 pm ] |
Damn buck brush is hard on shit |
Author: | CootSlayerRMFT [ Tue May 28, 2013 8:20 pm ] |
Are all PD tiller handles that long?! |
Author: | jordy [ Tue May 28, 2013 8:22 pm ] |
No, definitely am extension on the tiller. |
Author: | marsh chicken [ Tue May 28, 2013 8:52 pm ] |
Take some fine mesh and wrap it around the pump to keep the mud, grass, etc out of it. Works good |
Author: | msm8281 [ Tue May 28, 2013 8:54 pm ] |
Author: | forever draggin [ Tue May 28, 2013 9:48 pm ] |
I got 2 tsunami 1200 |
Author: | forever draggin [ Tue May 28, 2013 10:28 pm ] |
I never had a problem. They sit a Lil higher and kind of have a screen to where it's actually pulling water instead of trash. |
Author: | forever draggin [ Tue May 28, 2013 10:47 pm ] |
Ur welcome! |
Author: | renovator [ Wed May 29, 2013 5:13 am ] |
Yes it has 12" extension. With the hunt deck I was sitting on the false transom to drive. That with a floating handle is nice. The impeller on the 2000 is giant compared to the 1100 -1200. It should be able to pass whatever gets pass the grate made into the base. |
Author: | Prodigy [ Wed May 29, 2013 8:25 am ] |
Here is a setup i just did w 2 1500 manuals and a Bilge PumpSwitch Junior..........These dudes will sling some water................ Just be aware of the draw on the 2000 or 2 1500's.........big diff compared to the typical size bilges http://store.waterpumpsupply.com/ru12vodcnobi.html |
Author: | Bigrich [ Wed May 29, 2013 8:35 am ] |
I bet they do get rid of some water! |
Author: | renovator [ Wed May 29, 2013 3:42 pm ] |
I have the led running lights and the manual bilge switch on a 15 amp fuse. And the auto switch is on a separate fuse. |
Author: | idabilly [ Wed May 29, 2013 10:38 pm ] |
Have run a Rule 2000 on every mud boat I have ever owned. |
Author: | Fletch [ Fri May 31, 2013 3:04 am ] |
You could use that as a jet drive pump. ![]() |
