It is currently Mon Jul 21, 2025 9:42 am
Reply to topic  [ 22 posts ]
 2000 gph bilge pump
Post 2000 gph bilge pump
If your boat has this profile with a big engine, and you run deep water to get to shallow water. Then you should know why its needed :D
1648 gd hull flying in front of a stage 3 with fpr
Tue May 28, 2013 7:04 pm
Post Re: 2000 gph bilge pump
Wish I would have gotten bigger. I have the 500.
Tue May 28, 2013 7:18 pm
Almost sunk twice with a 750. Now its 2000 and nothing less.
Tue May 28, 2013 7:23 pm
I was gonna do that but I went with dual 1100's that way if one goes out I still have a back up
Tue May 28, 2013 7:26 pm
Thought of that but I wanted something with a big impeller to help cut/pass grass and mud.
Tue May 28, 2013 7:34 pm
Yeah that's a good idea for sure! My shit never seems to work right so always need a spare!
Tue May 28, 2013 7:45 pm
:lol: My shit always worked until grass hit it :D
Tue May 28, 2013 7:49 pm
Sticks would b my issue
Tue May 28, 2013 8:08 pm
Damn buck brush is hard on shit
Tue May 28, 2013 8:16 pm
Are all PD tiller handles that long?!
Tue May 28, 2013 8:20 pm
No, definitely am extension on the tiller.
Tue May 28, 2013 8:22 pm
Take some fine mesh and wrap it around the pump to keep the mud, grass, etc out of it. Works good
Tue May 28, 2013 8:52 pm
Tue May 28, 2013 8:54 pm
I got 2 tsunami 1200
Tue May 28, 2013 9:48 pm
I never had a problem. They sit a Lil higher and kind of have a screen to where it's actually pulling water instead of trash.
Tue May 28, 2013 10:28 pm
Ur welcome!
Tue May 28, 2013 10:47 pm
Yes it has 12" extension. With the hunt deck I was sitting on the false transom to drive. That with a floating handle is nice. The impeller on the 2000 is giant compared to the 1100 -1200. It should be able to pass whatever gets pass the grate made into the base.
Wed May 29, 2013 5:13 am
Here is a setup i just did w 2 1500 manuals and a Bilge PumpSwitch Junior..........These dudes will sling some water................
Just be aware of the draw on the 2000 or 2 1500's.........big diff compared to the typical size bilges
http://store.waterpumpsupply.com/ru12vodcnobi.html
Prodigy Boats
https://www.facebook.com/Prodigyboats
www.prodigyboats.com
Contact for info - http://prodigyboats.com/contact-us/
706-253-7766
Wed May 29, 2013 8:25 am
I bet they do get rid of some water!
Wed May 29, 2013 8:35 am
I have the led running lights and the manual bilge switch on a 15 amp fuse. And the auto switch is on a separate fuse.
Wed May 29, 2013 3:42 pm
Have run a Rule 2000 on every mud boat I have ever owned.
Wed May 29, 2013 10:38 pm
You could use that as a jet drive pump. :)
Fri May 31, 2013 3:04 am
Users browsing this forum: No registered users and 107 guests
