DIXIE MUD MOTORS
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=41760
Page 1 of 2
Author:  whitson218 [ Sat Jun 15, 2013 9:46 am ]
Post subject:  DIXIE MUD MOTORS
IF YOU LIKE HAVING A HEADACHE AND CONSTANTLY WORKING ON SOMETHING YOU OUGHT TO BUY ONE ! :twisted:
Author:  mizzippi jb [ Sat Jun 15, 2013 9:49 am ]
Post subject:  Re: DIXIE MUD MOTORS
Author:  txkingfisher [ Sat Jun 15, 2013 12:27 pm ]
hallelujah, he finally saw the light!
I was wondering when he was going to stop defending all the broken shit in his review....
(Disclaimer: I have absolutely no room to talk shit since my first mm is still being built... )
On the upside, I do hope you can get all the kinks worked out of your rig and get some trouble free hours on it! :)
Author:  Fowlweather80 [ Sat Jun 15, 2013 3:48 pm ]
What happened this time?
Author:  mizzippi jb [ Sat Jun 15, 2013 4:11 pm ]
Author:  whitson218 [ Sat Jun 15, 2013 4:50 pm ]
The bolts holding the clutch on broke in half.
Author:  Team Camo [ Sat Jun 15, 2013 4:52 pm ]
What??!!!!!
Author:  bayouboy [ Sat Jun 15, 2013 5:09 pm ]
X2 What??
Author:  Team Camo [ Sat Jun 15, 2013 5:10 pm ]
Pics!!!!
Author:  Fowlweather80 [ Sat Jun 15, 2013 7:08 pm ]
Yeah ive seen it before bad design,bolts cant handle that much torque with the heat transfer from engine block. I bet you had to break out the vise grips
Author:  Ben_ huntin [ Sun Jun 16, 2013 7:30 am ]
Have seen it happen twice to the same motor
Author:  whistlingwings [ Sun Jun 16, 2013 7:52 am ]
viewtopic.php?t=39589
Author:  Barroll [ Sun Jun 16, 2013 4:38 pm ]
I saw a Dixie for the first time this weekend. I don't understand why they leave the clutch housing open. Anything can get in there and cause all sorts of issues. You get what you pay for.
Author:  Team Camo [ Sun Jun 16, 2013 5:01 pm ]
Posting pics for whitson
Author:  Team Camo [ Sun Jun 16, 2013 5:04 pm ]
uploadfromtaptalk1371423845279.jpguploadfromtaptalk1371423821508.jpguploadfromtaptalk1371423802963.jpg
Author:  fowllife08 [ Sun Jun 16, 2013 5:13 pm ]
So at this point in time would you recommend a dixie surface drive?
Author:  mizzippi jb [ Sun Jun 16, 2013 5:15 pm ]
Damn....that could have been disastrous.
Author:  bayouboy [ Sun Jun 16, 2013 5:23 pm ]
Mercy, that looks fun.
Why did they put the clutch on the outer part of the shaft/backwards? Its exerting all the forces on the end of the bolts!. You need to address that issue or it will happen again. The easiest thing to do is make a clutch bolt carrier plate bolted on the outside the belt housing and run the bolts throw the plate then to the engine block. It will be supported on both ends.
IF it was mine I would flip that clutch around the right way, and redesign the engine mount.
Author:  cmk07c [ Sun Jun 16, 2013 5:57 pm ]
Man just see if you can get your money back. Too bad lemon laws don't apply to these like they do cars. Man if you want to save just buy a used long tail or a proven long tail. Good luck with that.
Author:  whitson218 [ Sun Jun 16, 2013 6:28 pm ]
Tried to get money back it says all over the owners manual ( 4 pages of diagrams ) no refunds. Yes I know I was excited to get my first mud motor and I defended mike but this is just way out of line. Yes he has sent me parts ( did not fix it..I did ) but something has broken on this thing every time I have taken it out.
Author:  Kmoppert [ Sun Jun 16, 2013 6:29 pm ]
viewtopic.php?t=41088
Author:  Fowlweather80 [ Sun Jun 16, 2013 6:32 pm ]
Author:  brasso [ Sun Jun 16, 2013 6:53 pm ]
Hate to say this... .but I told ya so
Author:  Kmoppert [ Sun Jun 16, 2013 7:08 pm ]
Author:  brasso [ Sun Jun 16, 2013 7:11 pm ]
Author:  Team Camo [ Sun Jun 16, 2013 7:51 pm ]
MB puts theirs on the outside also. The problem with the way Dixie is doing it is the bolts have to be so long to make it work. Too much leverage pushing on it like that. Looks like you can rotate the clutch 180* and put a single, shorter bolt thru the belt housing. That'd eliminate the torque from leverage on it & stop the broken bolts.
Author:  bayouboy [ Sun Jun 16, 2013 8:03 pm ]
Author:  625browning [ Sun Jun 16, 2013 9:13 pm ]
Man i really hate to hear this, i ordered the 23hp. Havent ran it yet, hope to in a week or so.
Author:  msm8281 [ Sun Jun 16, 2013 9:23 pm ]
Id back out if u can...but that's me. It seems all the owners are working on them more than using them.
Author:  whitson218 [ Sun Jun 16, 2013 9:47 pm ]
Author:  txkingfisher [ Mon Jun 17, 2013 1:10 am ]
It wouldnt be too hard to fabricate an aluminum spacer that locks all that shit together and eliminates the twisting action. Without the twisting, a pair of grade 8 bolts should more than handle the sheering loads.
Author:  Fowlweather80 [ Mon Jun 17, 2013 4:27 am ]
Author:  txkingfisher [ Mon Jun 17, 2013 7:33 am ]
I would like to hear this guy's reasoning for designing that shitt...... seriously........
"Yeah , I'm just going to hang these two long @$$ bolts out here to take all the torque. It's gonna be so fukkin awesome!" :roll:
Author:  Fowlweather80 [ Mon Jun 17, 2013 9:46 am ]
It used to be only 1 bolt, i snapped it everytime i took the boat out caused me to snap my belt opening day eve. Told him the design was b.s. i added 2 bolts he said he didn't understand why i was having this issue,made it sound like I was the only one at 1st haha more b.s. i questioned the fact about the clutch being on the end of the crankshaft an was told the manufacturer of the clutch wouldn't warranty it being mounted the other way due to heat coming off of the motor. I told Ben @ Dmm i was going to add another bolt i did and on the 3rd run 1 outta 2 broke. Therefore i told him 2 won't work either, so i installed all thread with coupler nuts and drilled thru belt box and jamm nutted everything together. Ran fine after that for 20 or so hrs til clutch finally went out and i scrapped the entire assembly and switch to direct drive.
Author:  whitson218 [ Mon Jun 17, 2013 10:18 am ]
That's the point I'm at. Going direct drive. And selling it.
Author:  Fowlweather80 [ Mon Jun 17, 2013 10:23 am ]
Author:  whitson218 [ Mon Jun 17, 2013 10:30 am ]
Just motor. I like the boat. What all is involved in making it direct drive ?
Author:  Fowlweather80 [ Mon Jun 17, 2013 10:42 am ]
Author:  RootSumn [ Mon Jun 17, 2013 10:44 am ]
Two of my buddies that have Dixie 35's had to unhook their clutch's last year. Bearing going bad or something. Sounded like a space ship going across the lake.
Author:  whitson218 [ Mon Jun 17, 2013 11:20 am ]
Well apparently they have started putting short bolts into the belt housing to hold the clutch better a couple weeks after they built my motor. So that issue has been addressed.
Page 1 of 2 All times are UTC - 6 hours
