It is currently Sat Jul 19, 2025 7:05 am
Reply to topic  [ 31 posts ]
 Longevity/Durability in Saltwater?
Post Longevity/Durability in Saltwater?
And I don't mean brackish. I mean saltwater.
GTR 25 and an Instagator boat. What can I do if I want to use this boat in the wintertime down in the coastal Everglades or fish Florida Bay in the summertime to minimize corrosion-related issues? What are the main problem points on the motor, and is the aluminum able to withstand saltwater?
I also have a Merc Sea Pro 25 outboard I can hang on the boat, if necessary, for the salt trips. Is it worth swapping?
Wed Jul 03, 2013 9:08 am
Post Re: Longevity/Durability in Saltwater?
pintail that is the best avatar on this site :lol:
WC Custom 1854 huntdeck pushed by MB7000
Wed Jul 03, 2013 9:22 am
Paint the motor to inhibit corrosion. Then coat with corrosion x. Also, it wouldn't hurt to add a saltwater anode somewhere on your drive system.
Wed Jul 03, 2013 9:25 am
Good info, thx.
For the Corrosion-X fans, there is a product made by CRC called Heavy Duty Corrosion Inhibitor that is a corrosion-proofing film similar to corrosion block or corrosion-x, but creates a thich, almost wax-like coating that effectively waterproofs whatever it touches. It's excellent for electrical connections/wiring/terminals or bare metal. I'm not sure how it will work on an air-cooled motor as they run quite a bit hotter than an outboard, but it really works well in most applciations and I like it a lot better than corrosion-x.
Wed Jul 03, 2013 9:31 am
Keep in mind that corrosion x is also a very good lubricant.
Wed Jul 03, 2013 9:38 am
Wed Jul 03, 2013 10:04 am
you wont be a guinea pig if you do the three:
Paint
Corrosion X (or any reputable inhibitor)
Anode
I have all three on my motor and I run saltwater damn near every time I take my boat out. You will be satisfied with the results.
Wed Jul 03, 2013 10:09 am
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Wed Jul 03, 2013 10:11 am
I'm willing to bet your gtr will stand up to the salt better than that outboard. I spray mine down with wd40 almost every time I use it. It looks like shit but its not corroded! I run saltwater just like 90% of the mm users do.
Wed Jul 03, 2013 10:18 am
Corrosion x is good but if you pressure wash a lot it don't stay on.
17x48 extreme stage 2 GTR
Wed Jul 03, 2013 10:25 am
Wed Jul 03, 2013 11:00 am
If your motor ain't gonna be sitting in the water for long periods anode ain't gonna do you any good.
As for as salt water pressure wash after each use that is you best defense.
Wed Jul 03, 2013 12:06 pm
Do you guys that are dousing your motors with wd40 and corrosion x not have alot of problems with bolts backing out everywhere?
Wed Jul 03, 2013 12:14 pm
Wed Jul 03, 2013 12:33 pm
Wed Jul 03, 2013 12:39 pm
Wed Jul 03, 2013 1:13 pm
So that is we're you keep it. I don't think it would last very long so your a clear water pirate lol
Wed Jul 03, 2013 1:41 pm
Wed Jul 03, 2013 1:54 pm
Wed Jul 03, 2013 1:58 pm
That's a clean ass motor. You paint it after every outing. Being that I guide in salt water I see no need for a anode on the motor if not left in the water for any amount of time. Just a FYI it's not only salt water. If you live close to water and keep your boat, camp in a place with under ground electricity wires its even worse. Fresh water also
Wed Jul 03, 2013 2:02 pm
Wed Jul 03, 2013 2:05 pm
Wed Jul 03, 2013 2:16 pm
I know of a couple surface drives that stay in saltwater during duck season. As in they are never picked up, they stay in the bayou until seasons over. These motors needed anodes, I personally don't believe it's needed if your not leaving it in the water. Can it hurt, no, so if you're so inclined to put one then go ahead.
All the solutions mentioned will afford some degree of protection. I personally just rinse mine off with fresh water but I don't do it often enough and it shows. Then again I really don't worry about it either.
Wed Jul 03, 2013 2:29 pm
Wed Jul 03, 2013 3:03 pm
Wed Jul 03, 2013 3:05 pm
Wed Jul 03, 2013 3:11 pm
I fish tampa bay weekly all salt bro wash it good it will be fine , i spray mine down about every other trip out and when I put it up I spray it. Its never in fresh water.
1746 with a modded 35 gdsd
Capt Team total asalt
Thu Jul 04, 2013 12:14 pm
Wow! Didn't mean to start a pissing match. Barnes, thanks for the pic. I'll probably put one on mine simply because salt water is the devil and any little bit helps. There may be times when I have it docked over the weekend in Salt Water. So...Thanks. DDM, Drive it like you stole it bro and I like your Jenson Radio. Niqqas!
Thu Jul 04, 2013 10:40 pm
Has anyone found a paint or primer that will stick to the block for any length of time?
1944 skiff with 35 GTR
Fri Jul 05, 2013 4:42 am
I buy the gallon of WD40, and a spray bottle keeps cost down a bit. I also use corrosion x after I pressure wash the engine. Rinse it ASAP and every time you get out the water.
Also, I hear that urange powder coat stops corrosion instantaneously.
35GTR on 1544 Weldcraft.....for now.
Fri Jul 05, 2013 6:42 pm
Wed Jul 10, 2013 7:15 am
Users browsing this forum: No registered users and 95 guests
