GTR25 Torque Tab
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=42621
Author:  BKScripto [ Sun Jul 07, 2013 7:38 pm ]
Post subject:  GTR25 Torque Tab
Took my boat out for the first time yesterday and had a ton of tiller torque. Not much torque until I got up to around half speed and then it started to torque into me, took a lot to hold it straight. We moved weight around and made sure everything was balanced.
I just wanted to be 100% on what I need to bend, I didn't see it in the manual. And, I assume I need to bend it more in the direction that it's already bent (towards port side)? Check out the pic... Lemme know if that's the only piece I need to bend.
Author:  fowllife08 [ Sun Jul 07, 2013 7:43 pm ]
Post subject:  Re: GTR25 Torque Tab
Yes.
Author:  eljefe [ Sun Jul 07, 2013 8:53 pm ]
Das it....mines at about 45 degrees...
sent from the former Republic of Texas.
Author:  BKScripto [ Mon Jul 08, 2013 10:57 am ]
Thanks guys. Is it worth trying to move the motor over an inch or so to see if that helps first? I don't have much room at all on my transom, but may have about an inch to play with.
Author:  Gameover [ Mon Jul 08, 2013 10:58 am ]
i found that bending tab at more effect than moving motor over
Author:  BKScripto [ Mon Jul 08, 2013 11:53 am ]
Cool thanks. I was told bending the skeg should be a last resort but it seems like it should be the first thing to try, assuming nothing weird is going on with the way it's mounted to the transom (way off center, etc).
Author:  Will [ Mon Jul 08, 2013 11:57 am ]
Owen can bend it for ya
Author:  rudyeng [ Tue Jul 09, 2013 5:47 pm ]
I bent both tabs and sharpened my skeg. Zero torque. runs great. (35 GTR)
Author:  Bigrich [ Tue Jul 09, 2013 5:52 pm ]
My skeg on 35gtr is one solid piece has no notches in it
Author:  mizzippi jb [ Tue Jul 09, 2013 5:59 pm ]
The 25 gtr I sold drove like an outboard. You could drive it with 2 fingers. Never bent the tab or nothing. I just hope the next one I get drives like that one did.
Author:  cut'em94 [ Tue Jul 09, 2013 6:45 pm ]
Can you bend it with something like a pipe wrench without messing it up?
Author:  Bigrich [ Tue Jul 09, 2013 6:48 pm ]
Yes
Author:  KENNEDY [ Tue Jul 09, 2013 6:49 pm ]
Sharpened your skeg? I take it you mean the leading edge. Is that so it cuts water and grass better? Never heard of this
Author:  rudyeng [ Tue Jul 09, 2013 8:52 pm ]
Not really sharp . Just tapered leading edge and rear tab so prop sees less turbulent water. My 35 gtr runs awesome.
That's my theory.
Not sure how much it helped but my 35 gtr pushes my boat nearly 30 mph stock. Boat is extremely fuel efficient as well.
Author:  KENNEDY [ Tue Jul 09, 2013 8:53 pm ]
Makes sense to me!
Author:  Will [ Wed Jul 10, 2013 4:39 am ]
Author:  mizzippi jb [ Wed Jul 10, 2013 5:38 am ]
Author:  pokey79 [ Wed Jul 10, 2013 5:45 am ]
I drove my new rig yesterday and it has bad tiller torque so I guess I need to bend mine too and I GPS 'd with a full ice and me and my daughter (75#) holding 28 mph at 3920 rpm
Author:  Will [ Wed Jul 10, 2013 5:49 am ]
Author:  Team Camo [ Wed Jul 10, 2013 5:52 am ]
Author:  pokey79 [ Wed Jul 10, 2013 6:21 am ]
Camo I just went look and ur rite so would should I do?
Author:  mizzippi jb [ Wed Jul 10, 2013 7:34 am ]
Author:  Team Camo [ Wed Jul 10, 2013 3:33 pm ]
Author:  pokey79 [ Wed Jul 10, 2013 4:38 pm ]
Yes 32 is what I have and thanks !!
