It is currently Mon Jul 21, 2025 5:10 am
Reply to topic  [ 18 posts ]
 hydraulic jack plate for a MM
Post hydraulic jack plate for a MM
is it pointless to have a hydraulic jack plate for a MM.
either a GTR or a PD
Gettin my rig in september and puttin one of those motors on it, but cant decide which one i want, anyways do hydraulic jack plates benefit you in anyway.
I've seen them on a boat with dual GTR's on it but that doesnt necassirly mean they benefit the boat, the person could just have an ego problem, lol
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Sat Jul 13, 2013 11:18 am
Post Re: hydraulic jack plate for a MM
Sat Jul 13, 2013 11:37 am
Friend has one on his GatorTail that really does great!He can lower that fuker deep in the mud if needed and raises it up while at idle to control his forward speed!seems to work for him.
Sat Jul 13, 2013 11:40 am
just curious if its worth the money, talk about having hydraulics. hydrauilc reverse, and hydraulics jack plate on a tiller handle.
I will deff get that bitch if its worth gettin
Sat Jul 13, 2013 2:35 pm
I would like to hear some reviews on this as well
17*38 Klibert 23GDLT
Sat Jul 13, 2013 3:00 pm
Sat Jul 13, 2013 3:01 pm
somebody got to have some info on this. im almost willing to buy one try it out and then sell it if it dont work like i want
Sat Jul 13, 2013 3:30 pm
How much further back will it set ur motor?
Sat Jul 13, 2013 3:37 pm
6 inches is what he had!
Sat Jul 13, 2013 4:22 pm
I have been thinking about this and just got to wondering if the trim unit on motor would hit transom when kicked up?Gonna be close!
Sat Jul 13, 2013 6:56 pm
I can see a jack plate on a regular outboard bc raises motor straight up to run in shallow water but way these are designed I can't see where would help really! That's just my thinking though
Sat Jul 13, 2013 7:39 pm
6" is what is needed and longer tension bolts or you will have to make a shim.
We put one on a 1860 CC we built for a guy who is a bass fisherman. We tested it in really shallow water with sand bottom where the boat was still floating but the motor couldn't get a bite. Raised the jack plate, trimmed motor down to where just the prop was in the water and were able to get moving and get back on plane over some distance. It created what i call the "helicopter" effect like PD FPR does with thrusting the back up the boat upward.
We don't have a lot of mud round here but my thoughts have been to set the jack plate 1/3 lower than the normal height and 2/3 higher to push the motor down for a deeper bite in the mud (like jimmy said) but still go higher to do what I described in cases like above.
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sat Jul 13, 2013 9:04 pm
I run jack plates on my dual rig and wouldn't want to be without them. Like Jimmy said they work well in the mud but what I like is balancing the weight in the boat. If I have three people standing at the rear of the boat with my driving I can just pull the motors up higher in the water. If I got a bunch of fish in the box on the front of the boat I can push the motors down to compensate the load.
Now for my tiller rig I wouldn't waist my money on one.
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sun Jul 14, 2013 5:09 am
yea it would be going on a tiller rig.
Sun Jul 14, 2013 5:14 am
I have decided I am getting a lot of vibration in my motors from the jackplates. You can hear them buzzing when running cause there has to be slack between the two brackets to allow for the motor to travel up and down. I would think you would feel this in your tiller handle.
Sun Jul 14, 2013 8:19 pm
What jack plate brand you use?
Don't argue with stupidity, it will only drag you down to their level and beat you with experience.
Sun Jul 14, 2013 8:39 pm
I run CMC I know a lot of people don't like them but if you mount the relays in a dry location your good to go.
Sun Jul 14, 2013 8:47 pm
talked to someone, said if ur having trouble gettin out of something, it allows you to drop that motor way down so it can get the best bite possible
Tue Jul 16, 2013 4:54 pm
Users browsing this forum: No registered users and 96 guests
