It is currently Tue Jul 22, 2025 1:37 am
Reply to topic  [ 30 posts ]
 Setting trailer bunks
Post Setting trailer bunks
Is there a trick to setting trailer bunks went pick up ma boat yesterday and it look like its. Nose diving big time. Before I put the boards on the trailer I dropped the boards all the way should the front of the boards be higher than the back
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Wed Jul 17, 2013 5:33 am
Post Re: Setting trailer bunks
Umm I would say so like that your oat would drain water when on the trailer
Wed Jul 17, 2013 6:15 am
I meant before I put boat on trailer I dropped the boards
Wed Jul 17, 2013 6:21 am
Your boards should be on the same plane as your trailer frame. You have a flat bottom boat right.
All things flat being equal they should be the on same horizontal run.
Yea it's a flat bottom boat. I thought maby cause the motor not on it or many cause the boards don't go far enough forward maby
Wed Jul 17, 2013 6:24 am
Ill take a pic and pos it up in a Lil while so y'all can see
Wed Jul 17, 2013 6:25 am
Boat on trailer
Wed Jul 17, 2013 8:01 am
Who built that?
Wed Jul 17, 2013 8:06 am
“Believe none of what you hear and half of what you see.”- Benjamin Franklin
"Advertisements contain the only truths to be relied on in a newspaper." -Thomas Jefferson
Wed Jul 17, 2013 8:12 am
Wed Jul 17, 2013 8:16 am
1754 GTB / 35 GTR
Wed Jul 17, 2013 8:17 am
Need to unbolt the bracket in the front where winch is and slide it and tighten back down should lift front o boat
Wed Jul 17, 2013 8:18 am
it looks like your trailer winch is mounted low on the support. may need to raise that and fall the bunks a lil.
1754 GTB / 35 GTR
Wed Jul 17, 2013 8:19 am
Chuckie a guy from louriville and yea it's a mcclain trailer I figured that if I put all the trailers bunks all the way down it couldn't get no flatter than that
Wed Jul 17, 2013 8:20 am
Wed Jul 17, 2013 8:21 am
Wed Jul 17, 2013 8:24 am
Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here"
23GTR stage 2 by Calen pushin a 1746 Kliebert
Most likely its the way that the axle is set up that is making the back of the trailer be so tall. Are the leaf springs mounted on top of the axle?
Wed Jul 17, 2013 8:27 am
I had it up a Lil bit but when I got home I dropped ima mess with it some more the boat should be flat on the boards on the front an back rite now the back of boat is off boards bout 1/4 inch I dropped it cause when he set it on the trailer and I winched it forward we had to pick it up by hand to get it over the roller. Every boat I had came ready to go so I don't know how to set all that stuff
Wed Jul 17, 2013 8:30 am
To me, you want the boat to sit flat on the trailer bunks, not raise up the front of the boat on the winch just for the sake of it being level.
Wed Jul 17, 2013 8:35 am
Wed Jul 17, 2013 8:45 am
Like I said I dropped the boards all the way. Unless its angled
Wed Jul 17, 2013 8:55 am
That's part of reason I got rid of my old boat I never noticed and the boat hung off trailer bout 6 inches and it made it hook in the back
Wed Jul 17, 2013 8:58 am
Don't think the boat is to front heavy its a 3/16 bottom with a6 ft deck how long should the runners be 10 ft
Wed Jul 17, 2013 9:16 am
What mine are
Wed Jul 17, 2013 9:18 am
Like aka said can u not mover the winch stand back tower it sit level
Wed Jul 17, 2013 9:19 am
Ima pull it in the shop after work and see if can pick it up with crane and set it
Wed Jul 17, 2013 9:34 am
I really figure that is what ur issue is
Wed Jul 17, 2013 10:20 am
Users browsing this forum: No registered users and 83 guests
