Broken PD https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=43130 |
Author: | craig [ Fri Jul 19, 2013 3:43 pm ] |
Post subject: | Broken PD |
When clutch is engaged, unit makes a thump/knock like noise but does not propel. Any ideas? |
Author: | Kmoppert [ Fri Jul 19, 2013 4:07 pm ] |
Post subject: | Re: Broken PD |
Where us the notice coming from? I broke one of the bands on an old clutch and it threw the disc off center and was hitting the brake plate. |
Author: | craig [ Fri Jul 19, 2013 4:32 pm ] |
I couldn't tell as I didn't get close enough. It's pretty loud though. He called H&H and was told "It's probably the spline shaft." I'm towing him in now. |
Author: | forever draggin [ Fri Jul 19, 2013 4:45 pm ] |
Potm |
Author: | Kmoppert [ Fri Jul 19, 2013 4:47 pm ] |
Yeah, the splines can round off on the upper shaft and/or the connector mounted to the clutch... |
Author: | Swampnuts [ Fri Jul 19, 2013 4:53 pm ] |
Craig, change your fuel filter. Sun beat that thing up |
Author: | JIMMY W [ Fri Jul 19, 2013 7:18 pm ] |
Sounds like a gear problem! |
Author: | CJB [ Fri Jul 19, 2013 7:25 pm ] |
Yea either the clutch is shot or the splines stripped somehow |
Author: | Kmoppert [ Fri Jul 19, 2013 7:36 pm ] |
Author: | calphil [ Fri Jul 19, 2013 8:53 pm ] |
Is that a Dixie pulling him in .. Last I heard they were the best mm Sent from... who cares.. |
Author: | duckduckboom [ Sat Jul 20, 2013 3:25 am ] |
Splined coupler. If you can turn the prop and feel clean resistance of the gears ad the clutch is spinning its the coupler. They are made to fail before the gears |
Author: | rodburner21 [ Sat Jul 20, 2013 6:41 pm ] |
PIPELINE CANAL ?? |
