It is currently Fri Jul 18, 2025 10:31 pm
Reply to topic  [ 11 posts ]
 Gator glide application question
Post Gator glide application question
Getting ready to install g2 on my boat and you guys that have done this where you mask off your lines do you pull the tape off after each coat? just wondering if i'll have an issue removing tape after 4,5, or 6 coats. Thanks
1856 Phowler commercial hull with extra flotation so I can run shallower. Pushed by a stock Prodrive until my wife gives me more money
Sun Jul 21, 2013 7:33 pm
Post Re: Gator glide application question
No I didn't pull mine off till I was done was careful and had a razor blade in case it didn't wanna separate and pull off but never had to use it
Sun Jul 21, 2013 7:38 pm
Leave the tape on until you've applied all coats and it has dried. I applied six coats of G2, letting each coat dry for ~30 minutes. I left the tape on until the next day. It peels right off.
Sun Jul 21, 2013 7:39 pm
Sun Jul 21, 2013 7:41 pm
Im glad you asked that. Cause i was gonna ask when i put it on my boat. do you have to sand down the bottom of the boat before you apply the g2
18x46 40.
Sun Jul 21, 2013 7:56 pm
Sun Jul 21, 2013 8:09 pm
ok thanks
18x46 40.
Sun Jul 21, 2013 8:20 pm
Yeah I used 220 grit and just hit it then wiped down with acetone
Sun Jul 21, 2013 8:22 pm
alright thanks
18x46 40.
Sun Jul 21, 2013 8:47 pm
I used 220 on a da sander then wipe it down with acetone. I put mine on the same day and took the tape off after the last coat.
Running a Alumacraft 1442 NCS with a 25 HP Orion surface drive. Not the best, but it works.
Mon Jul 22, 2013 9:44 am
thanks for the help fellas
Mon Jul 22, 2013 2:09 pm
Users browsing this forum: No registered users and 106 guests
