Aluminum gas tank dimensions https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=43363 |
Author: | benelli08 [ Thu Jul 25, 2013 6:13 am ] |
Post subject: | Aluminum gas tank dimensions |
I just got a custom boat built and I decided after the fact that I want to put a big tank. Cause I'm tired of having to switch between 2 6 gal tanks i want one 12. But the plastic 12 gal won't fit under my deck I only got 11 inches of clerance what I'm getting at is I found a formula online you type in length x width x height and it gives you how manny gallons. So to check it I put in measurements for a 12 gal plastic tank and it says the plastic should hold like 20 gal I gota be missing something |
Author: | da go get'er [ Thu Jul 25, 2013 6:19 am ] |
Post subject: | Re: Aluminum gas tank dimensions |
1 gallon is .1336 cu ft |
Author: | MNGunner [ Thu Jul 25, 2013 6:40 am ] |
Is your tank a perfect rectangular solid? |
Author: | benelli08 [ Thu Jul 25, 2013 6:51 am ] |
What tank. I don't get it built yet |
Author: | forever draggin [ Thu Jul 25, 2013 7:34 am ] |
They have an online calculator for this, u put n the l,w,h and it tells u how many gallons it will hold |
Author: | forever draggin [ Thu Jul 25, 2013 7:39 am ] |
I barely read op lol |
Author: | gfowel [ Thu Jul 25, 2013 7:57 am ] |
Author: | benelli08 [ Thu Jul 25, 2013 8:11 am ] |
I figured that's what. It was for. But a aluminum tank don't need air space and all that to ? |
Author: | Gtr18x42 [ Thu Jul 25, 2013 8:38 am ] |
Length x width x height=?? divide that by 231 that will give u the gallons it's close i figured mine to be 16 gallons at the pump it was 15.7 gallons to the top. Sent from my iPhone using Tapatalk |
Author: | Gtr18x42 [ Thu Jul 25, 2013 8:41 am ] |
I've never seen an aluminum tank with air space I don't build them with air space either. Sent from my iPhone using Tapatalk |
Author: | JLACOUR [ Thu Jul 25, 2013 8:49 am ] |
Author: | Jamie B. [ Thu Jul 25, 2013 10:03 am ] |
I painted mine and left a little window around mine so I could see the fuel level. I would not advise using it as a seat, they do flex a good bit. |
Author: | JLACOUR [ Thu Jul 25, 2013 10:09 am ] |
Thanks fellas. and you answered my next question about durability. Probably not a good route for me. Good idea about leaving a window if you paint it though! 27 PD FPR 16x36 skiff |
Author: | Gtr18x42 [ Thu Jul 25, 2013 5:18 pm ] |
Author: | JIMMY W [ Thu Jul 25, 2013 5:33 pm ] |
Go plastic!! |
