Modded B&S Carb From Gecker
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=4377
Page 1 of 8
Author:  JET DRIVE [ Fri Sep 04, 2009 10:40 am ]
Post subject:  Modded B&S Carb From Gecker
Checked out Gecker's website and I noticed they sell a modified B&S carb that they claim adds +/- 4hp. I'm all about some extra hp but I'm not wanting to get into the engine or go with the Mikuni carb but an upgraded B&S carb might be worth getting. I'm assuming it's an exact replacement just beefed up a bit and that all my current parts would work. I'm not wanting to change alot of stuff ie air filter etc.
Anybody familiar with this setup? Do you think the $ is worth the few extra hp or do you even think I'll notice the increase? Do you think it would be any more or less finicky or reliable than the stock one I have now?
Thanks.
Author:  gecker [ Fri Sep 04, 2009 11:16 am ]
Post subject:  Re: Modded B&S Carb From Gecker
We have a couple of options in this package that will increase HP from 4-6.5 total. You can go with the big bore stock carb or you can go with a infinite radius big bore stock carb. The increase is for sure noticable. We have done literally a thousand or more of these over the years. The net overall bore size is a lot larger than the Mikuni and it is stock. The carbs are very easy to tune. This package is a bolt on deal tailored toward your engine combination. You just bolt it on when you get it.
We will be offering a swap program very soon. Basically, send us yours and we replace it with a core here. Similar to getting an alternator for your car.
We also have in stock the air filters and air filter adapters if you are wanting to replace your stock air box.
Thanks
Author:  Crews [ Fri Sep 04, 2009 1:44 pm ]
if all I got was better low-end throttle response, I'd be happy! seems like there's always that little dead spot when you first get into it. possible?
Author:  marshbyrd [ Fri Sep 04, 2009 1:53 pm ]
yeah was thinking about the same thing i just want some better throttle response more like a boat less like a lawnmower. Im gonna wait until they do that core replacement deal. that plus some new pipes, and maybe head work in the future waiting for the warranty to dissapear.
Author:  OwenDickeson [ Fri Sep 04, 2009 3:00 pm ]
Gecker,
is there any kind of warranty on your stainless exhaust? also, do you have any pictures of the vertical 36 exhaust. thanks
Author:  gecker [ Fri Sep 04, 2009 5:11 pm ]
We have update the site with some pictures of the various intake system components that we make. Here is the link: http://www.mudboatmotor.com/html/performance_parts.html
Make sure to hit the refresh button if it does not look new. We will be updating the site very frequently with products pictures and new products.
With the stock carb, the potential for improvement is exxtremely great compared to anything else. If you look at the attached picture, you will see what we are saying. They are easy to tune and the flow great air. The net bore size is larger than a 42 Mikuni by a lot.
Crews, your low end response is going to be a lot better. It gets a ton better all the way through to the top side.
Marshbyrd, the replacement deal is on. We will post info on the site and I guess here before the weekend is out. We have carbs in stock and ready to go.
Owen, we will offer a warranty on it. We cannot post pictures yet for a couple of reasons. AS SOON as we can we will for sure.
Thanks
Author:  OwenDickeson [ Fri Sep 04, 2009 5:24 pm ]
sounds good. say i send you my carb to get it bored, how long am i lookin at til i get it back? also on the website you say that the cost is considerably less but i cant seem to find it anywhere and am interested. if you need to answer me in a PM please do so. thank you sir.
Author:  txduckkilla [ Fri Sep 04, 2009 5:26 pm ]
I have the same questions as Owen. If its a short turnaround I would like to send mine to you next week. If its a long turnaround, its gonna have to wait until Feb.
Author:  OwenDickeson [ Fri Sep 04, 2009 5:35 pm ]
Author:  POKER1 [ Fri Sep 04, 2009 10:50 pm ]
He said they carbs in stock and ready to go on the exchange deal.
Author:  shawnp2 [ Sat Sep 05, 2009 2:06 am ]
Can you do anything with the B&S 31?
Author:  txduckkilla [ Sat Sep 05, 2009 6:54 am ]
Author:  JET DRIVE [ Sat Sep 05, 2009 8:10 am ]
I'm gonna go with the new carb for sure and was thinking about the air filter set up but it looks like the filter would be exposed and I don't like that. Am I seeing the pictures of the air filter set up wrong or would the filter just mount to the adaptor via hose clamp and stick up without any type of cover on it. If so I'll stick with my stock set up and run just the new carb.
What kind of improvement might I see with just the carb and nothing else?
Author:  POKER1 [ Sat Sep 05, 2009 8:30 am ]
Author:  POKER1 [ Sat Sep 05, 2009 8:34 am ]
Author:  med [ Sat Sep 05, 2009 8:43 am ]
Author:  gecker [ Sat Sep 05, 2009 9:12 am ]
Our site has been updated with new info. Here is the link to the carb page:
http://www.mudboatmotor.com/html/hp_stock_carbs.html
If the info is not new, hit your refresh button. A whole heck of a lot more is going to be added soon so stay tuned!
Thanks
Author:  gecker [ Sat Sep 05, 2009 9:14 am ]
31's? No problem. We can perform basically the same operations on any style of carb or engine for that matter.
Thanks
Author:  gecker [ Sat Sep 05, 2009 9:23 am ]
The filters we are discussing are K & N or S & B Filters for stock carb applications. These are not cone style filters. Here is the dimensions: 8 3/4 x 4 3/4 x 4.
It does not stick out to bad and is secured to our air filter adapter. It works very well. It provides very little restiction and just as much protection from debris.
Thanks
Author:  med [ Sat Sep 05, 2009 9:51 am ]
how does the level 2 compare to the mikuni? or can they be compared......
Author:  50fps [ Sat Sep 05, 2009 1:33 pm ]
You're opening up the bore on the carb.
Are you also opening intake, or blending it?
Author:  POKER1 [ Sat Sep 05, 2009 3:39 pm ]
Author:  quackconsumer [ Sat Sep 05, 2009 5:24 pm ]
OK, I always said I was stayin stock. But you now have my attention wit these factory carbs dat yall put your majic on. My question is does this increase the odds of having future mechanical problems?
Author:  50fps [ Sat Sep 05, 2009 7:38 pm ]
Author:  POKER1 [ Sat Sep 05, 2009 9:15 pm ]
I guess that would be an additional charge. But I see what your getting at.
Author:  bayouboy [ Sat Sep 05, 2009 9:47 pm ]
Whats on the back of my mind is that there saying a bored and blended stock carb has more flow than a 42mm mukuni. which maybe it does, but with the restriction in air flow by the butterfly and choke valves in the stock setup. I just don't see it being as or more efficient than the smooth bore and slide valve of the Mukuni, especially at WOT. just mho.
But with that being said, If I had to do it all over again I would definitally give the modded stock carb a try before paying what I paid for the Mukuni!
Good price fosho!
Author:  LaBirdman [ Sat Sep 05, 2009 10:08 pm ]
So what I read is that a modded carb is free if your core passes?
We ship you a fully modified carb and charge you a $100 core charge. Once you get your new carb, ship us your old one. Once your carb gets here and passes core inspection, we refund your card the core charge. This means little down time and great performance right at your finger tips!
Author:  POKER1 [ Sat Sep 05, 2009 10:23 pm ]
No, it's 250 plus a 100.00 core charge. 100.00 credited back to you when they get your carb.
Author:  POKER1 [ Sat Sep 05, 2009 10:35 pm ]
Author:  bayouboy [ Sun Sep 06, 2009 3:27 am ]
Sure you'll be happy with it! 4+ hp gain at half the price!!
Author:  dpd [ Sun Sep 06, 2009 11:51 am ]
Author:  backwaterballer [ Sun Sep 06, 2009 12:04 pm ]
I think I'm gonna order a carb for my 23 next week some time
Author:  shallow water master [ Sun Sep 06, 2009 3:09 pm ]
ya it sounds like a good deal
Author:  duckmanck [ Sun Sep 06, 2009 11:47 pm ]
can my stock exhaust handle the big bore carb and the high perf. air filter
Author:  Crews [ Mon Sep 07, 2009 6:04 pm ]
Good question! I'd like to know that myself
Author:  bayouboy [ Mon Sep 07, 2009 6:51 pm ]
I know that my Mukuni didn't like a stock exhaust at all, the excess back pressure from the small diameter/restrictive muffler made the carb back flow. It also makes it difficult to get a smooth and responsive carburetion through the entire rpm range. :?
Author:  gecker [ Tue Sep 08, 2009 6:04 am ]
The stock exhaust can handle it. We have done several that way. You can also modify the stock exhaust somewhat making it better.
On the intakes, we do a lot of blend work and roll it all in. You are limited but still can make it better.
Thanks
Author:  Mitschke [ Tue Sep 08, 2009 10:09 am ]
Author:  duckmanck [ Tue Sep 08, 2009 10:23 pm ]
well just bought the carb upgrade and the intake. my question is do i need to get a rev limit increase????????
Author:  POKER1 [ Tue Sep 08, 2009 11:46 pm ]
Page 1 of 8 All times are UTC - 6 hours
