It is currently Sat Sep 06, 2025 6:56 pm
Reply to topic  [ 9 posts ]
 what hp mud motor for a 1448 polar kraft mv
Post what hp mud motor for a 1448 polar kraft mv
Im looking in to a mud motor for my 1448 mv polar kraft. I want to be able to reach between 20-25 mph. What would be the best surface drive or LT?
Sat Oct 26, 2013 1:06 pm
Post Re: what hp mud motor for a 1448 polar kraft mv
18hp Copperhead would be perfect since its relatively light... but you are using a mod-v so know one knows how well it will work
1754 Beavertail - 35hp SD
Sun Oct 27, 2013 9:01 am
Here are some pics of the boat if it helps.
Mon Oct 28, 2013 2:51 pm
I've got the same hull (except a 1442). I was just about to order a 23 hp backh2o longtail until common sense took over and told me not to spend the money with only a month left of the season. But i will probably be putting one on for next year. If you end up with a copperhead I'd like to know the performance since it is a fairly unique hull shape. It is mostly flat bottom except for the mod v which is only in the rake.
Every day I'm paddlin'
Mon Oct 28, 2013 8:05 pm
I was also thinking about the backwater but just don't know what hp to get. I've bein doing a lot of research and found that the backh2o will push faster than almost all other LTs, and with a lot less maintenance. But I would also like the surface drive because of the speed but I don't want to order one and find that it wont perform how id like it to.
Mon Oct 28, 2013 8:15 pm
23 Copperhead will work for you.
Mon Oct 28, 2013 8:36 pm
What about any LT ideas, or will the surface drive perform better?
Tue Oct 29, 2013 2:34 pm
Depends on your conditions. I like longtails for a majority if what i do, although I've only ran a few surface drives. The longer runs I've got are manageable with the longtail, but it shines when you get on windy tight trails and you need the reach.
Tue Oct 29, 2013 3:18 pm
I had a 16' same hull with a 48 evinrude only 31
Very heavy boat
16X48 WELDBILT -25GTR EFI-sold
18x48 GTB - 35 GTR
Crown royal pro-staff
Tue Oct 29, 2013 3:30 pm
