Just got a 18x48 Go-Devil Boat https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=4706 |
Author: | lsurebel4 [ Fri Sep 18, 2009 10:41 am ] |
Post subject: | Just got a 18x48 Go-Devil Boat |
Does anyone have this boat? If you do, what motor are you running on it? What type of perfomace are you getting. Do you like the boat, first off? I have never owned a surface drive motor ever, and I am trying to determine what I want. Any opinions greatly appreciated? I would like to have reverse, reliability, and the ability to move with 3 peeps and gear. |
Author: | oleman [ Fri Sep 18, 2009 10:49 am ] |
Post subject: | Re: Just got a 18x48 Go-Devil Boat |
If reverse is required, you will need either a PD (shaft driven) or GT(belt driven). Suggest looking at both first before buying. |
Author: | quackconsumer [ Fri Sep 18, 2009 11:49 am ] |
Author: | Mitschke [ Fri Sep 18, 2009 12:06 pm ] |
Shafter on here is running an 1848 GD boat with a 36 ProDrive. Wait for him to chime in. |
Author: | lsurebel4 [ Fri Sep 18, 2009 12:56 pm ] |
Ok, just so I have my duckies straight. ProDrive and GatorTail are the only surface drive engines that have reverse? Which one has the full power reverse that has to be swiveled, and which one has reverse with the gear or button that needs to be pressed? Lastly, do these motors have neutral? Love the forum, great wealth of info. |
Author: | dog walker [ Fri Sep 18, 2009 1:02 pm ] |
Pro drive-Full Power Reverse Gator tail-instant reverse Both have neutral and they are the only surface drives with reverse |
Author: | mcnemar1982 [ Fri Sep 18, 2009 1:06 pm ] |
Prodrive has full power reverse. Both have neutral. Gatortail and prodrive are great motors. You should for sure go drive em b 4 u buy. ![]() |
Author: | quackconsumer [ Fri Sep 18, 2009 1:08 pm ] |
Here are der web sites. http://www.prodriveoutboards.com http://www.gator-tail.com |
Author: | lsurebel4 [ Fri Sep 18, 2009 1:29 pm ] |
Has anyone ever ridden in a 18x48 Go Devil boat with either a Pro Drive or a Gator- Tail 35/36HP? The boat to me seems kind of heavy. Just curious as to how this boat will perform with this motor. I come from a Mudboat background with a v6 chevy engine. Lots of maintenance involved. Although it was bad to the bone, I think these surface drives would give it a run for the money. |
Author: | quackconsumer [ Fri Sep 18, 2009 1:41 pm ] |
If you're concerned bout da weight remove all da floataion from da boat and convert dat space to dry storage. Dat will get rid of a few hundred pounds. |
Author: | lsurebel4 [ Fri Sep 18, 2009 2:08 pm ] |
The boat, according to Go-Devil Website is 550 pounds. If you remove the flotation in the floor, do you think that would lose 100 pounds? I thought that was just foam. Sorry for the questions, I am a newbie. |
Author: | slambin [ Fri Sep 18, 2009 2:38 pm ] |
Author: | dog walker [ Fri Sep 18, 2009 3:27 pm ] |
Darrel from Meraux has a 20x44 go devil boat with a 31 gdlt and a 31 gator tail that he has put a carb on and head work I believe.With the gator tail he was running about 30 with 2 people but both of them combined don't wiegh 300 pounds,dey some little mofo's.You can pm him and get some info. |
Author: | eaglebeak [ Fri Sep 18, 2009 6:55 pm ] |
I got a 1848PDCC with a 36PD, ran it with 3 people (280lbs., 190lbs., 175lbs.) and 6 gal. of fuel, it ran 25mph in deep water, i also took a spend buy my self (175lbs.) and ran 28.8, boat only has 1hr. on it, think it will pickup a mph or 2 once it breaks in. Also think full power reverse is the way to go. |
Author: | shallow water master [ Fri Sep 18, 2009 7:18 pm ] |
Author: | Gigafowl [ Fri Sep 18, 2009 8:00 pm ] |
Hunted out of the 18 48 GD this mornin' - - with a smile and a limit... 35 GDSD an a 12" push pole - 28 plus solo and 26 with 3 average dudes - 24 with some hosses and a big ice chest.... Reverse is fer weenie polishers.... |
Author: | LA OUTLAW [ Fri Sep 18, 2009 8:15 pm ] |
Author: | kibb [ Fri Sep 18, 2009 9:37 pm ] |
Author: | lsurebel4 [ Mon Sep 21, 2009 6:25 am ] |
Thanks for all of the info guys. I appreciate the help. I tried to look at the foam in the boat, but the floor is riveted to frame around the foam. I popped one of the rivets and the foam looked black. Does Go-Devil or anyone sell the foam new? I don't want to rip out and start over if I can't find the replacement. Also, who deals sell the Gator Tail and Pro Drive motors in the New Orleans area? Do they have them in stock? |
Author: | schrieverboy [ Mon Sep 21, 2009 6:34 am ] |
where r u from exactly?? |
Author: | Wingman [ Mon Sep 21, 2009 6:37 am ] |
Call Go Devil pretty sure they will ship you replacement foam or you can let them do the work for you you are close enough to all the brands to deal with them directly from N.O. and get test rides too |
Author: | BradS [ Mon Sep 21, 2009 6:39 am ] |
Author: | jpc014 [ Mon Sep 21, 2009 7:19 am ] |
Author: | jpc014 [ Mon Sep 21, 2009 7:24 am ] |
