Fuel pump problems will this work https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=48596 |
Author: | benelli08 [ Wed Dec 25, 2013 9:54 am ] |
Post subject: | Fuel pump problems will this work |
Ok here is ma situation think it will work but not sure went hunt yesterday and got out there ran through some shtick stuff. Ok I have cdi motor with the fuel pump on the side the motor and a mikuni carb we'll the barb coming from the fuel line broke going in to the fuel pump and my hose was not long enoughy to reach the carb direct so I used a butt connector to connect the two fuel lines to get back to the landing so here is my question a while back my manifold broke and my buddy gave me one off a old motor. We'll that fuel pump on the motor has that extra hose going to the manifold but it's not connected cause the old manifold does not have that but I have a electrical fuel pump. Can I just run the fuel line direct to the carb or do i need that fuel pump On top the motor also |
Author: | bayouboy [ Wed Dec 25, 2013 11:39 am ] |
Post subject: | Re: Fuel pump problems will this work |
![]() It will run fine with the electric pump, but imo I would just replace the stock vacuum pump. I have no faith in the electric ones especially for a primary. Use the electric for a primer and back up. |
Author: | benelli08 [ Wed Dec 25, 2013 1:33 pm ] |
Even though it does not have the line going to the manifold the stock vacuum will still work |
Author: | AKA Freshwaterkilla [ Wed Dec 25, 2013 1:38 pm ] |
Author: | dfou [ Wed Dec 25, 2013 2:08 pm ] |
Author: | benelli08 [ Wed Dec 25, 2013 4:00 pm ] |
Yea I guess I could drill and tap it out bieng that I work at a machine shop |
Author: | benelli08 [ Wed Dec 25, 2013 8:43 pm ] |
Y'all wouldn't happen to know what thread it is I'm. Sure it's a npt thread that way it tighten up as you screw it in but will the size of the ID of the fitting matter |
Author: | AKA Freshwaterkilla [ Wed Dec 25, 2013 9:01 pm ] |
Author: | bayouboy [ Wed Dec 25, 2013 11:23 pm ] |
As long as its not 3/8, 1/2, 3/4, 1", etc... lol Go 1/8npt my boy. |
Author: | benelli08 [ Thu Dec 26, 2013 4:54 am ] |
Yea I was thinking 1/8 cause we do a lot of 1/4 npt and that would be way to big cause a 1/4 npt is a 7/16 drill bit |
Author: | bayouboy [ Thu Dec 26, 2013 4:17 pm ] |
^ Exactly |
Author: | benelli08 [ Fri Dec 27, 2013 5:08 am ] |
For the time bieng it's getting hooked direct because I called gator tail that lil piece is like $120 and I don't have time to take the manifold off and drill and tap it but thanks for the help it'll get done eventually |
