War eagle problems https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=48786 |
Author: | Gatortail2010 [ Thu Jan 02, 2014 7:37 am ] |
Post subject: | War eagle problems |
I have a 648 lab wareagle with a 35 gatortail on it and absolutely love the boat and motor. Only problem is when I have a load ("three guys, no telling how many dozen decoys, blind bags, guns, and dog") it takes a stretch to finally get on plane. What do I do to fix this? Is there any way to?? Or should I just chunk this one and get a new riffle next year? Someone told me Pods would help a lot but take away some of the turn radius? Just need some advice on this any would be appreciated! |
Author: | Gatortail2010 [ Thu Jan 02, 2014 7:41 am ] |
Post subject: | Re: War eagle problems |
648 ldv* sorry auto correct got me |
Author: | lilfukr79 [ Thu Jan 02, 2014 7:51 am ] |
Wrong style boat for a mudmotor. I had a 1754 war eagle and when loaded down wouldnt plane ever. Boat would do just fine when light laoded. Best answer is to get different boat made for mudmotors. Pods mite help some but wont be best fix for performance. |
Author: | dirtybird29+ [ Thu Jan 02, 2014 9:09 am ] |
Get a true mud hull will be you r best bet. Sent from my iPhone using 2 |
Author: | JIMMY W [ Thu Jan 02, 2014 9:16 am ] |
Get with Hoyt at GatorTail and tell him you need some mods ![]() |
Author: | tinman454 [ Thu Jan 02, 2014 9:44 am ] |
You need a different boat, or you need more power added to the motor. That is the only two answers there is. |
Author: | mudxxed [ Thu Jan 02, 2014 10:15 am ] |
Nothing you can do other then more power or different boat. I run a 1651 excel and 35 dixie. Love both motor and boat. Dont run mud like alot of guys here. Not that I wouldnt love to, we just dont have the tides here in SE Bama. For what I need the boat/motor does GREAT. 3 guys and all gear I run 15... Solo 25ish. 2 guys around 22 with gear. If Im that concerned over 2-3mph Ill just leave 2-3 minutes sooner |
Author: | DENNYEDWARDS [ Fri Jan 03, 2014 12:09 pm ] |
Regear your prop shaft to a 50 or 52 tooth sproket or go to a flater pitched prop, with less dia. |
Author: | odass [ Sat Jan 04, 2014 1:33 pm ] |
another vote for a different hull. ribbed boats cause turbulance at top of qwater and cause prop to blow out. mods will help,and so will a longer outdrive.good luck |
Author: | brickgw [ Sat Jan 04, 2014 1:36 pm ] |
I have the same problem with my 18 ft MV when running 4 guys. Lookin to upgrade boats myself come spring time. |
Author: | odass [ Sun Jan 05, 2014 5:29 pm ] |
Author: | jc [ Sun Jan 05, 2014 6:54 pm ] |
Author: | brickgw [ Sun Jan 05, 2014 7:19 pm ] |
I don't consider myself and 3 passengers to be a considerable load unless I'm dragging out an ass ton of decoys with them. Although myself and most of the guys I hunt with weigh 200 lbs or less. |
Author: | Woodiebuster [ Mon Jan 06, 2014 5:32 pm ] |
You need an 18' mud hull. |
