how do i remove gator glide ? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=49116 |
Author: | Hernaja1 [ Mon Jan 13, 2014 7:17 am ] |
Post subject: | how do i remove gator glide ? |
just a quick question. how do u remove gator glide ? paint thinner ? wanting to remove the gator glide on the side of the boat. to repaint the side and transom of the boat. would be grateful for some tips or answers. |
Author: | mud slinger 69 [ Mon Jan 13, 2014 7:19 am ] |
Post subject: | Re: how do i remove gator glide ? |
Grinder with a sanding pad on it or wire wheel on it. |
Author: | Will [ Mon Jan 13, 2014 7:19 am ] |
sander |
Author: | Hernaja1 [ Mon Jan 13, 2014 7:35 am ] |
ok thanks. the gator cglide is way up on the side walls of the boat. I had hope I could soften it up with a paint thinner or something and just scrape it off. but I looks like sometimes there no easy way about it |
Author: | Will [ Mon Jan 13, 2014 8:04 am ] |
I bet you can just scuff it with 120 grit and paint over it. |
Author: | bengtr35 [ Mon Jan 13, 2014 10:18 am ] |
I had to do the same on a boat I bought. First I tried to sand it and that did not work. 2nd I tried aircraft stripper and that was a joke. 3rd. I used a flap disk with 120 grit and it would clog in no time. 4th. It was a pain but I did it. a wire wheel worked the best. It was messy. Make sure to ware a dusk mask. Here is the before and after: |
Author: | Will [ Mon Jan 13, 2014 10:55 am ] |
Wait and see what Frog says, I still think you can paint over it. |
Author: | Hernaja1 [ Mon Jan 13, 2014 11:22 am ] |
I'm tempted to scuff the gator glide up with a light grit sand paper and use a self etching primer then paint it |
Author: | JIMMY W [ Mon Jan 13, 2014 1:07 pm ] |
Call frog ![]() |
Author: | Frog [ Mon Jan 13, 2014 1:38 pm ] |
Nobodies ever removed GG before.. You mad at yourself??? ![]() |
Author: | Frog [ Mon Jan 13, 2014 1:50 pm ] |
if you are not going back with the GG on the sides...can't imagine why??? you need to get it really clean and go over with a good etching primer! |
Author: | dirtybird29+ [ Mon Jan 13, 2014 2:10 pm ] |
Author: | missile [ Mon Jan 13, 2014 2:44 pm ] |
makes me feel better about how well mine will hold up now. LOL |
Author: | TPerkins [ Mon Jan 13, 2014 5:17 pm ] |
Only Chuck Norris can remove that stuff! |
Author: | nasty [ Mon Jan 13, 2014 5:45 pm ] |
Think he just wants it off the sides not the bottom |
Author: | Frog [ Mon Jan 13, 2014 6:54 pm ] |
Author: | Hernaja1 [ Mon Jan 13, 2014 7:43 pm ] |
Yes it's half way up the side of the boat. I just want it off the sides. The previous owner put it on the boat, which I'm glad it's on there just not that high up on the sides, I'm not removing it off the bottom. the boat could us a paint job so I want to remove the existing gator glide of the side. |
Author: | msm8281 [ Mon Jan 13, 2014 7:48 pm ] |
JMHO but I would just paint up to gg instead of going through all that trouble fir such little reward. But hey it's your boat so what do I care:lol: |
Author: | Hernaja1 [ Mon Jan 13, 2014 8:09 pm ] |
Might as well not paint it then. Covers almost more then half the side if my boat. I might just leave alf a foot of the gator glide at the bottom. |
Author: | Frog [ Mon Jan 13, 2014 8:32 pm ] |
Author: | Hernaja1 [ Tue Jan 14, 2014 4:59 am ] |
Can do. Yea there's paint under the gg on the sides. I do like the gator glide to a certain degree but not that far up on the sides. So I plan on going ahead and removing all the gg and re painting the boat. Once I'm done I might put GG 2-3 inches on the side |
