prodrive or godevil can't decide
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=49651
Author:  fins&feathers [ Sun Jan 26, 2014 9:02 pm ]
Post subject:  prodrive or godevil can't decide
i cant decide on what i want. i'm between a gdsd and a prodrive both 35hp. Any advice? pros and cons
Author:  missile [ Sun Jan 26, 2014 9:04 pm ]
Post subject:  Re: prodrive or godevil can't decide
Do more homework
Author:  JLACOUR [ Sun Jan 26, 2014 9:04 pm ]
That should be easy
Author:  cb5331 [ Sun Jan 26, 2014 9:06 pm ]
Wrong forum...
Author:  JLACOUR [ Sun Jan 26, 2014 9:11 pm ]
I had to go look it up, but for a sec I thought u were the one that started this thread
viewtopic.php?t=48848
Author:  CootSlayerRMFT [ Sun Jan 26, 2014 9:24 pm ]
I'm a GDSD owner and I vote PD. I've run both. Take that for what it's worth... ;)
Author:  WhoDat88 [ Sun Jan 26, 2014 9:24 pm ]
Well you may want to check your boat first.
As far as a motor it is pretty simple. If you are going to be around a ton of thick grass then go prodrive. If you like simple easy to maintain motor that runs smooth then go GDSD. I own a GDSD. I love the customer service and how smooth it is to drive and easy to maintain. I usually do not have many issues with mud. However, every time I am playing in thick grass I usually leave wishing I had a GTR or PD. the GDSD runs great wide open in grass. It does not idol well in grass. The trim tabs catch the grass. The GDSD runs decent in rough water. Not sure about the others. You will have 100 different people tell you a hundred different things on here. Everyone will claim to know it all and have the best motor ever. Take your time and read about each motor before deciding. Real the owners manuals and make your decision. These are two completely different motors that operate completely different. You can lift the GDSD out of the water with one finger and it is easy on a transom. The PD is heavier on the transom. The PD does not need trim tabs to stay in the water. Go devil is a meat and potatoes engine. One is belt driven and the other uses gears. Research and research some more. Call both places. Go see them live. Make your decision after that
Author:  kibb [ Sun Jan 26, 2014 9:34 pm ]
I run a GDLT. I have never run an SD. Ditch the GDSD and Prodrive. GTR all the way!! :lol:
Author:  banded-mallard [ Mon Jan 27, 2014 6:36 am ]
Author:  med [ Mon Jan 27, 2014 6:57 am ]
No brainer. Pd.
Author:  Quacks & Tracks [ Mon Jan 27, 2014 6:11 pm ]
When I was shopping for my first new surface drive I looked at them all. I kept coming back to the GTR. I don't regret it. Good in mud, great in grass. I'm an old man and need the reverse for loading. I'd be your nightmare around a ramp w/o a reverse. I put it on the Gator tail extreme.
Author:  gatorslayer [ Mon Jan 27, 2014 7:00 pm ]
OP it's all ford dodge Chevy.
You guys are a bunch of idiots full of yourselves on the Internet. If you don't like a godevil your not driving one. STFU read my sig its for you gay bitches.
Author:  BERNIE255 [ Mon Jan 27, 2014 7:43 pm ]
Author:  JIMMY W [ Mon Jan 27, 2014 8:06 pm ]
I would go with a poodrive before I would go with godevil junk :lol: good luck!
Author:  JLACOUR [ Mon Jan 27, 2014 8:27 pm ]
Author:  Hernaja1 [ Mon Jan 27, 2014 8:31 pm ]
GD are good motors but no brainier . PD ! No brainier .
Author:  BERNIE255 [ Mon Jan 27, 2014 8:36 pm ]
Author:  banded-mallard [ Tue Jan 28, 2014 12:10 pm ]
Author:  med [ Tue Jan 28, 2014 1:02 pm ]
Selling my gdsd was more about the lack of neutral. Having small kids and a dog made me very uncomfortable having my motor running and the prop spinning. I was fine with the motor other than that. But, after owning a pd theres not going to be another brand switch in my forseeable future. Reverse has gotten me out of a lot of situations that would have left me stranded had I not had it. Kp and peck are good ppl and have helped me out quite a bit. I suggest you drive the 2 and then make your descision.
Author:  BERNIE255 [ Tue Jan 28, 2014 1:27 pm ]
Author:  Quacks & Tracks [ Wed Jan 29, 2014 10:18 am ]
Hey Gator Killer - Is your command of the English language really so restricted that you can only use profanity to express your view(s)? You neither impress or intimidate.
Author:  eljefe [ Wed Jan 29, 2014 10:58 am ]
If you only needed to go forward, the go devil is a good choice .... but fpr is really beneficial. Tiller torque is practically non existent on the pro drive. I drove my old pd last weekend and realised how much I miss some aspects of it.... I really miss some of its width. 54" bottom make a very comfortable stable hull.
Sent from my SCH-I545 using Tapatalk
Author:  mattpittinger [ Thu Jan 30, 2014 9:56 pm ]
By a Pro-drive if you want a simple motor that's easy to drive with and live with. Unless you want the rippling biceps of a go devil owner, then Go Devil all the way.
Author:  meterman3 [ Thu Jan 30, 2014 10:11 pm ]
gonna catch hell for this but i have both , now have a pro drive 18x54 cc with all the bells and whistles , came from a gd , i am going back to a go devil 16x60 with a 35 . the gd was a better built hull and a lot less maintenance if u don't need rev , a go devil is hard to beat
service for both is top notch so that is not a problem .
the prodrive 3rd rev. cyl , real heavy , slower than the godevil , hull has not held up as well as the godevil did i could go on , but the gd
hull took the same abuse and show nothing like the pd hull has
just my 2 cents
mac
