mud motor weight on wood transom https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=50166 |
Author: | jimsmith2003 [ Sat Feb 08, 2014 7:34 pm ] |
Post subject: | mud motor weight on wood transom |
i have a 15 foot jon boat with a wood transom i was wondering if putting a 23 hp mini mudbuddy motor on there would wear out the wood transom. also has anyone put on the beaver tail pods on the back of there jon boat |
Author: | Hernaja1 [ Sun Feb 09, 2014 2:18 am ] |
Post subject: | Re: mud motor weight on wood transom |
I wouldn't do it . To much wieght and torgue |
Author: | brickgw [ Sun Feb 09, 2014 7:02 am ] |
When you say wood transom are you saying that its all wood an no aluminum or just a wood core? I had to rebuild the transom in my Jon boat last spring and I beefed it up. It's got a wood core and its holding up to my 36 pd real good. |
Author: | jimsmith2003 [ Wed Feb 12, 2014 1:28 pm ] |
Its a wood core |
Author: | North LA Hunter [ Wed Feb 12, 2014 1:51 pm ] |
Author: | Hernaja1 [ Wed Feb 12, 2014 6:02 pm ] |
If ur not using the motor what it's meant for ( going through mud ) then ur fine. If it goin through a lot of mud good luck. Mud boat are thicker then standard aluminum boats for a reason. |
Author: | Puddler45 [ Thu Feb 13, 2014 2:50 pm ] |
I ran a 23 MB HD on my 14' lowe with a wood core transom I reinforced the transom I put it through its paces jumpin muskrat huts hittin logs breaking ice ect and had no problem but I only ran it one season. Just rock what you got until you can afford a better boat. I used aluminum angle iron attached to rear seat and transom and ran some square tubing for supports to tie it all together. |
