It is currently Wed Jul 16, 2025 3:04 am
Reply to topic  [ 7 posts ]
 mud motor weight on wood transom
Post mud motor weight on wood transom
i have a 15 foot jon boat with a wood transom i was wondering if putting a 23 hp mini mudbuddy motor on there would wear out the wood transom. also has anyone put on the beaver tail pods on the back of there jon boat
Sat Feb 08, 2014 7:34 pm
Post Re: mud motor weight on wood transom
I wouldn't do it . To much wieght and torgue
Sun Feb 09, 2014 2:18 am
When you say wood transom are you saying that its all wood an no aluminum or just a wood core? I had to rebuild the transom in my Jon boat last spring and I beefed it up. It's got a wood core and its holding up to my 36 pd real good.
Sun Feb 09, 2014 7:02 am
Its a wood core
Wed Feb 12, 2014 1:28 pm
Wed Feb 12, 2014 1:51 pm
If ur not using the motor what it's meant for ( going through mud ) then ur fine. If it goin through a lot of mud good luck. Mud boat are thicker then standard aluminum boats for a reason.
Wed Feb 12, 2014 6:02 pm
I ran a 23 MB HD on my 14' lowe with a wood core transom I reinforced the transom I put it through its paces jumpin muskrat huts hittin logs breaking ice ect and had no problem but I only ran it one season. Just rock what you got until you can afford a better boat. I used aluminum angle iron attached to rear seat and transom and ran some square tubing for supports to tie it all together.
Thu Feb 13, 2014 2:50 pm
Users browsing this forum: kib876 and 87 guests
