A lil help please https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=50990 |
Page 1 of 2 |
Author: | benelli08 [ Sun Mar 02, 2014 10:06 am ] |
Post subject: | A lil help please |
Boat is not performing like it should be with no load I have a stage 2 by Calen. The motor pushes hard no dout about that. it's on a 18x48 with 3/16 bottom with 1/8 sides with catwalk and a 6 ft deck with a 14 gal alunimum tank up front can't seem to get it over 30 what I don't understand ran it last night with 4 people 2 batteries ice chest pulled out my gps running 29-30 and it does the same if I'm by my self with that load I was turning 4150 seemed to be the sweet spot with a load. But I can't figure out why it won't run by my self |
Author: | LA Prop [ Sun Mar 02, 2014 2:56 pm ] |
Post subject: | Re: A lil help please |
because its a mud motor not a race boat thats where it should run niglet |
Author: | JLACOUR [ Sun Mar 02, 2014 4:05 pm ] |
Author: | benelli08 [ Sun Mar 02, 2014 4:57 pm ] |
If La prop woukd ever build me a good prop. A loaded boat should not run the same as the a empty one |
Author: | OwenDickeson [ Sun Mar 02, 2014 6:19 pm ] |
Are you running a stock Gator-Tail prop? |
Author: | WhoDat88 [ Sun Mar 02, 2014 6:20 pm ] |
Author: | benelli08 [ Sun Mar 02, 2014 7:18 pm ] |
It's a stock prop but it's modified the guy I got it from had a bead welded along the edge of each blade to make it last longer. And it was to much prop for him so I bought it off him cause we run a lot of sand it held up all season but yea it is a stock prop that i know of |
Author: | Zeek569 [ Sun Mar 02, 2014 8:15 pm ] |
Take that big ass tank out the front nick you might have to much weight in the front and when we goin ride agin? |
Author: | benelli08 [ Sun Mar 02, 2014 8:21 pm ] |
Idk and I can't have a gas tank in my feet when I'm Driving. My old boat I had 2 6 gal tanks in the front. Ima just have to accept it it's a heavy boat I'm Sure a new prop would help but I'm not going buy a. New one and it's no diffrent |
Author: | OwenDickeson [ Sun Mar 02, 2014 8:21 pm ] |
I'd try a new prop. Sent from my XT1080 using Tapatalk |
Author: | mud slinger 69 [ Mon Mar 03, 2014 5:57 am ] |
If those speeds are real dont know what the problem is not many boats can run that fast with 4 boys and gear. |
Author: | 50fps [ Mon Mar 03, 2014 6:55 am ] |
RPM-Speed ratio seems about right. |
Author: | duckduckboom [ Mon Mar 03, 2014 6:56 am ] |
How many Rpms are you running by yourself ? |
Author: | benelli08 [ Mon Mar 03, 2014 9:04 am ] |
That's what in saying the boat does awesome with a load just don't preform by my self. Rpm by my self are at like 4500 -4600 Rpm loaded Down is 4100-4150 |
Author: | benelli08 [ Mon Mar 03, 2014 9:11 am ] |
Just ask LaProp he knows how I am about speed I blame ma dad for that |
Author: | OwenDickeson [ Mon Mar 03, 2014 9:16 am ] |
I would try a new stock prop before anything. Your boat isnt hooked? |
Author: | duckduckboom [ Mon Mar 03, 2014 9:22 am ] |
I would measure the prop before buying a new one. Worn props normally equal higher Rpms. I would check te throttle linkage. You may not get getting the full travel j would also talk to Calen and see what you out of the water Rpms should be at. But I would imagine you should be getting somewhere close to 4500 |
Author: | OwenDickeson [ Mon Mar 03, 2014 9:24 am ] |
Im not saying its worn, just thinking the modifications to it may be keeping it from running fast. |
Author: | benelli08 [ Mon Mar 03, 2014 9:28 am ] |
I just got it back from Calen wendesday he just went through it and fixed everything he said it's running perty good and that boat better not be hooked I just had that boat built with 3/16 bottom and extra braces on the bottom cause I Usto have a gator tail hull but in two years the area we run destroyed the bottom it was hooked in 3 spots I'll measure the prop when I get home |
Author: | BayouBuster [ Mon Mar 03, 2014 9:29 am ] |
If they welded a bead on the backside of the leading edge it will slow it down. That's why Hopkins props don't run as fast because they are so thick on the leading edge. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | dfou [ Mon Mar 03, 2014 9:39 am ] |
I would agree its a prop issue if the speeds are the same at 4100 and 4500 Sent from my iPhone using Tapatalk |
Author: | benelli08 [ Mon Mar 03, 2014 9:40 am ] |
Good Info prop why ma boat ain't been running for the past 6-7 months since I put that prop on I just never knew cause I put the prop on right when I got the new boat |
Author: | duckduckboom [ Mon Mar 03, 2014 9:41 am ] |
Shit I kissed that part about 4500. Get a new prop |
Author: | benelli08 [ Mon Mar 03, 2014 9:42 am ] |
Guess I'll have to break down and buy another prop and just use that one for huntin season when gota run the bad stuff. I wish gator tail would let me test run the new 3 blade |
Author: | dfou [ Mon Mar 03, 2014 9:42 am ] |
They will for 240$ ![]() Sent from my iPhone using Tapatalk |
Author: | benelli08 [ Mon Mar 03, 2014 9:46 am ] |
My buddy let me use his. He has one if the first ones that they used for testing I ran it this weekend I noticed that the prop is not pulling with the tips of the blades cause they still have that rough texture while the base of the prop is smooth but I put on my 2 blade with the same load and the 2 blade out preformed it better hole shot and top end idk if that prop is just a bad one or what but I wasant impressed with it and it's heavy I know It got another blade on it but still |
Author: | benelli08 [ Mon Mar 03, 2014 9:48 am ] |
Idk why they can't let you test them they know me and they what 5 min from the lake I'll even let hyot come run it with me |
Author: | 50fps [ Mon Mar 03, 2014 10:48 am ] |
Author: | 270Handiman [ Mon Mar 03, 2014 10:58 am ] |
Surface drive props are relatively cheap....just buy it. |
Author: | benelli08 [ Mon Mar 03, 2014 11:03 am ] |
Free hat that's a good one I'm suprised they don't charge for the candy in the front office |
Author: | BayouBuster [ Mon Mar 03, 2014 11:29 am ] |
Take a grinder with a buffing pad to the backside of the one you have and make it a knife edge. If it fixes the problem you know its the prop if it doesn't then have a bead welded back on it like you have now. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | benelli08 [ Mon Mar 03, 2014 11:50 am ] |
I'll take a pic of it when I get home today |
Author: | benelli08 [ Mon Mar 03, 2014 3:40 pm ] |
This is the prop |
Author: | OwenDickeson [ Mon Mar 03, 2014 4:32 pm ] |
You dont know anyone with a stock gator-tail prop in good condition? |
Author: | benelli08 [ Mon Mar 03, 2014 4:39 pm ] |
Brand new no we all run the same area and mines the one with the Least wear. And it had about a 3/8 thick bead along the whole thing you can tell it wore our more on the sides than the tips |
Author: | OwenDickeson [ Mon Mar 03, 2014 4:54 pm ] |
I think a stock prop will bump you up to around 32 maybe 33 mph deep water. |
Author: | benelli08 [ Mon Mar 03, 2014 5:02 pm ] |
Guess I'll just have to buy one and see so y'all think the 2 blade reigns over the 3 blade everybody got different opinions |
Author: | BayouBuster [ Mon Mar 03, 2014 5:42 pm ] |
Looks like they welded up the front side too. Buff that weld down and see what happens. I like the 3 blade I bought but I haven't ran it enough to know if I'll like it in the thick grass. I have a feeling ill run my 3 blade for fishing and 2 blade for frogging. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | benelli08 [ Mon Mar 03, 2014 5:47 pm ] |
I may just keep the prop like it is cause it's really tough that's a whole season of running sand and stumps and it still does decent keep it for the tough stuff and get a 3 blade for like you said cursing and fishing |
Author: | THE TANK [ Tue Mar 04, 2014 1:11 am ] |
Nick 4 guys running that speed is good man! It runs loaded, and that's all you can ask for, but you still can't beat THE TANK! You try, I got to fine you that. I'm fixing to build be a new 18X46 like you had and we going to hook em up! Sent from my iPhone using Tapatalk |
Page 1 of 2 | All times are UTC - 6 hours |
