New tack https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=52202 |
Author: | TDUET [ Wed Apr 09, 2014 4:02 am ] |
Post subject: | New tack |
Tinny Tack went out.. Best place to get a new one?? |
Author: | banded-mallard [ Wed Apr 09, 2014 4:45 am ] |
Post subject: | Re: New tack |
Author: | baron von [ Wed Apr 09, 2014 6:22 am ] |
Post subject: | Re: New tach |
i see a lot of Tiny Tach problems/failure here - is it advised to replace it right off the bat and be done with it? |
Author: | banded-mallard [ Wed Apr 09, 2014 7:56 am ] |
Here is a video so you can see it in action. |
Author: | OwenDickeson [ Wed Apr 09, 2014 7:58 am ] |
Author: | TDUET [ Wed Apr 09, 2014 8:05 am ] |
Ive owned 3 GTR's. First one leasted a good while.. 2nd one lates maybe 40hr.. This one lasted 100hr. My luck is not that good it seems. lol |
Author: | Will [ Wed Apr 09, 2014 8:06 am ] |
Only issue I had was moisture getting behind the face and fogging it up. I called Tiny Tach and it's an easy fix. Slip your knife or a very small flat head screw driver under the corner of the clear front "screen" and it'll peel off. Then clean it and carefully put a thin layer of clear silicone around the frame of the cover and put it back on. Resealed from the elements and problem solved. |
Author: | Bayoublackhunter [ Wed Apr 09, 2014 10:50 am ] |
I been having mine from 2012. Has over 500 hrs with no issues sent from the marsh |
Author: | DeltaRunner [ Thu Apr 10, 2014 3:49 am ] |
Author: | NORTHFLORIDAFOWLER [ Thu Apr 10, 2014 8:50 am ] |
mine prodrive is an 08 and tach is still kickin just fine |
Author: | Old School [ Fri Apr 11, 2014 7:32 am ] |
Looks like a good one, |
Author: | krazo [ Wed Apr 23, 2014 8:03 am ] |
i used a Hardline HR-8061-2 and it worked great. got it from amazon less than 30 bucks. stores max rpm |
Author: | Glade [ Thu Apr 24, 2014 10:32 am ] |
Some cool new options coming soon from Tiny Tach. I will have a backlit one to check out soon. If your tach malfunctions, you can peel the transparent label off, then use a razor knife to cut out the sealant on the circuit board. Then bridge the 2 exposed solder points. It will reset. Squirt some silicone in there, replace the label, and ride into the sunset. |
Author: | missile [ Thu Apr 24, 2014 6:26 pm ] |
I been asking for a backlit tach for my dual rig so keep us posted |
