Thoughts on seat bases on rear boxes???
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=52502
Author:  Fooshman [ Sat Apr 19, 2014 2:38 pm ]
Post subject:  Thoughts on seat bases on rear boxes???
Trying to decide on a layout for a boat.
Trying to decide whether or not to get some seat bases on top of the two rear boxes or not...
What are yalls thoughts?
Author:  willett [ Mon Apr 21, 2014 6:26 am ]
Post subject:  Re: Thoughts on seat bases on rear boxes???
No rear boxes at all. They just get in the way.
Cooler or movable seat bases are the way to go
Author:  eljefe [ Mon Apr 21, 2014 6:44 am ]
X2.... Open hull.... put your gun box in front deck.....movable seat bases are awesome... and will help to balance load in boat....
Author:  SwampSlut [ Mon Apr 21, 2014 11:37 am ]
i put one on my drivers box for my tempress nav seat and it works good... id suggest installing yourself so you can get placement right. mine landed perfect for driving and just far enough forward to turn towards me while im in the seat. also if you cant find one with a closed post hole find a rubber furniture leg end to keep water out your box.
Author:  The Shafer [ Mon Apr 21, 2014 11:38 am ]
Open hull all the way!
USe the removable seat bases like Willett makes or make a removable box (cube) that has a lid on it for storage.
Author:  Russ [ Mon Apr 21, 2014 11:50 am ]
I prefer a box in the back, as long as I have a boat cusion, dont need the full seat. If you do prefer a seat, positioning matters most, or you'll hate it. Thats why movable bases are better in many cases. Having a base on yhe passenger side wont help, cause you likely thatwont ever want someone else that far back in the boat.
Author:  OwenDickeson [ Mon Apr 21, 2014 12:12 pm ]
Why would you ever have to remove a small drivers box?
Author:  eljefe [ Mon Apr 21, 2014 12:59 pm ]
I took it out of my old pd.... it was a bolt on small drivers box and when I stood and drove, it was right where I was comfortable standing.... With my seat base in the new hull I can sit a drive and when I get to the parts of the bayou that has a lot of turns I stand up and move seat out of my way....I move around a lot to shift my weight to grab an edge on the turns.... If I stay on the high side it will flatten hull and slide.
Author:  OwenDickeson [ Mon Apr 21, 2014 1:03 pm ]
I've had a PD, and that drivers box is not small. :lol:
Author:  OwenDickeson [ Mon Apr 21, 2014 1:05 pm ]
I mean something like this.
Author:  txbackwater [ Mon Apr 21, 2014 3:13 pm ]
Author:  OwenDickeson [ Mon Apr 21, 2014 3:31 pm ]
WC Custom Boats
Author:  barnes_53 [ Mon Apr 21, 2014 4:39 pm ]
Hydroturf with seat pad
Author:  PhilD [ Mon Apr 21, 2014 7:46 pm ]
Barnes is the the PD you had built? Looks good.
Later
Phil
