It is currently Mon Jul 07, 2025 4:37 am
Reply to topic  [ 12 posts ]
 braaaaapp!
Post braaaaapp!
Did a little searchin and couldnt find much. On the newer GTR'S i beleive it has 4 holes correct? Which hole are yall putting it in for best results?
35 GTR chasin a BBC 1848
Sat May 03, 2014 5:30 am
Post Re: braaaaapp!
My 25 is on top with a quick pin .. Stock pin in bottom for when mud gets tic
1744 WC Custom
25 GTR
Sat May 03, 2014 5:34 am
Post Re: braaaaapp!
gonna vary depending on your boat and transom...but whatever pin it runs best on make sure you have a removable pin so you can drop all the way down if necessary, this has gotten me out of a bind many times
1944 skiff with 35 GTR
Sat May 03, 2014 5:40 am
Post Re: braaaaapp!
So factory pin on bottom hole and 'removable' on desired hole? Just askin because i nwver understood it the holes made that much of a diference? Bout to make a makeshift pin. Can someone measure the width of the transom mount? So i can drill a hole for cotter? Thanks!
Sat May 03, 2014 5:43 am
Post Re: braaaaapp!
The 4th hole added was out lower than the previous ones so new models go extra low. And in mud pin location helps drastically it allow u to trim much lower
Sat May 03, 2014 8:03 am
Post Re: braaaaapp!
Mine runs in second pin
1852 Dfou custom 35gtr
Sat May 03, 2014 10:22 am
Post Re: braaaaapp!
Mine is in the second one as well
Sent from my SAMSUNG-SGH-I337 using Tapatalk
35 Mud Buddy ON 1652 WELDCRAFT
Sun May 04, 2014 9:28 am
Post Re: braaaaapp!
17x54 Extreme W/ GTR-35L Stage 1
Sun May 04, 2014 10:33 am
Post Re: braaaaapp!
Sun May 04, 2014 11:13 am
Post Re: braaaaapp!
Can some one put up a pic of this pin thing I don't understand how this works. Do you need to pull a pin out when you need to trim the motor ? Or is it to hold the motor up after you trim? What is this pin for?
08 35 mudbuddy, gator traxx 3 man hide.
Sun May 04, 2014 11:20 am
Post Re: braaaaapp!
Sun May 04, 2014 6:09 pm
Post Re: braaaaapp!
Sun May 04, 2014 6:11 pm
Users browsing this forum: No registered users and 114 guests
