braaaaapp!
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=52929
Author:  fowllife08 [ Sat May 03, 2014 5:30 am ]
Post subject:  braaaaapp!
Did a little searchin and couldnt find much. On the newer GTR'S i beleive it has 4 holes correct? Which hole are yall putting it in for best results?
Author:  calphil [ Sat May 03, 2014 5:34 am ]
Post subject:  Re: braaaaapp!
My 25 is on top with a quick pin .. Stock pin in bottom for when mud gets tic
Author:  Nate [ Sat May 03, 2014 5:40 am ]
gonna vary depending on your boat and transom...but whatever pin it runs best on make sure you have a removable pin so you can drop all the way down if necessary, this has gotten me out of a bind many times
Author:  fowllife08 [ Sat May 03, 2014 5:43 am ]
So factory pin on bottom hole and 'removable' on desired hole? Just askin because i nwver understood it the holes made that much of a diference? Bout to make a makeshift pin. Can someone measure the width of the transom mount? So i can drill a hole for cotter? Thanks!
Author:  Gameover [ Sat May 03, 2014 8:03 am ]
The 4th hole added was out lower than the previous ones so new models go extra low. And in mud pin location helps drastically it allow u to trim much lower
Author:  doubleBanded [ Sat May 03, 2014 10:22 am ]
Mine runs in second pin
Author:  KeNnY [ Sun May 04, 2014 9:28 am ]
Mine is in the second one as well
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Author:  MarshJB [ Sun May 04, 2014 10:33 am ]
Author:  doubleBanded [ Sun May 04, 2014 11:13 am ]
Author:  tinman454 [ Sun May 04, 2014 11:20 am ]
Can some one put up a pic of this pin thing I don't understand how this works. Do you need to pull a pin out when you need to trim the motor ? Or is it to hold the motor up after you trim? What is this pin for?
Author:  doubleBanded [ Sun May 04, 2014 6:09 pm ]
Author:  doubleBanded [ Sun May 04, 2014 6:11 pm ]
