It is currently Wed Jul 09, 2025 3:41 pm
Reply to topic  [ 14 posts ]
 How many rpms
Post How many rpms
I had my rig out for the first time today prodrive 36 on a 1854 and 3400 was the highest rpms I could get out of it should I be getting more?
Sat Jun 07, 2014 7:36 pm
Post Re: How many rpms
Yes you should be getting more (assuming you're not carrying around elephants) . What year/model is your pd?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Sat Jun 07, 2014 7:40 pm
2012 with me my brother probably 550 between us and some fishing gear
Sat Jun 07, 2014 7:44 pm
Pd hull?
Verify throttle is fully opening.
Verify out of water rpms.
Are you new to surface drives? 3400 rpm was at your best speed?
Sat Jun 07, 2014 7:52 pm
Yea pd hull
New to surface drives and the rpm were at top speed
I have not tried it out of the water
Sat Jun 07, 2014 8:03 pm
They take some getting use to. Start by making sure your butterfly in the carb is fully opening and see what the oow rpms are.
Sat Jun 07, 2014 8:16 pm
Okay thanks I will try them tomorrow
Sat Jun 07, 2014 8:36 pm
I can get 4200 out of the water what if anything should I try next time I am out
Sun Jun 08, 2014 8:05 am
You should be at 4350 so adjust your governor. Again pull your filter to make sure you are fully open at wot.
Did you buy it from someone on here?
Sun Jun 08, 2014 8:50 am
No I bought it on ebay it was a coast guard boat they bought it only has ten hours on it out of water in gear or not I can get 4200 easy I will check butterfly
Sun Jun 08, 2014 8:59 am
The butterfly opens all the way
Sun Jun 08, 2014 12:30 pm
2-3 years old with 10 hours; could be a fuel or carb issue.
Sun Jun 08, 2014 12:45 pm
It runs fine out of the water and in the water it runs good just not getting up rpms in water like when out of water is it something I am doing
Sun Jun 08, 2014 1:01 pm
Clean the carb.
Sun Jun 08, 2014 7:12 pm
Users browsing this forum: No registered users and 91 guests
