How many rpms https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=53796 |
Author: | biglinz1 [ Sat Jun 07, 2014 7:36 pm ] |
Post subject: | How many rpms |
I had my rig out for the first time today prodrive 36 on a 1854 and 3400 was the highest rpms I could get out of it should I be getting more? |
Author: | JLACOUR [ Sat Jun 07, 2014 7:40 pm ] |
Post subject: | Re: How many rpms |
Yes you should be getting more (assuming you're not carrying around elephants) . What year/model is your pd? |
Author: | biglinz1 [ Sat Jun 07, 2014 7:44 pm ] |
2012 with me my brother probably 550 between us and some fishing gear |
Author: | JLACOUR [ Sat Jun 07, 2014 7:52 pm ] |
Pd hull? Verify throttle is fully opening. Verify out of water rpms. Are you new to surface drives? 3400 rpm was at your best speed? |
Author: | biglinz1 [ Sat Jun 07, 2014 8:03 pm ] |
Yea pd hull New to surface drives and the rpm were at top speed I have not tried it out of the water |
Author: | JLACOUR [ Sat Jun 07, 2014 8:16 pm ] |
They take some getting use to. Start by making sure your butterfly in the carb is fully opening and see what the oow rpms are. |
Author: | biglinz1 [ Sat Jun 07, 2014 8:36 pm ] |
Okay thanks I will try them tomorrow |
Author: | biglinz1 [ Sun Jun 08, 2014 8:05 am ] |
I can get 4200 out of the water what if anything should I try next time I am out |
Author: | JLACOUR [ Sun Jun 08, 2014 8:50 am ] |
You should be at 4350 so adjust your governor. Again pull your filter to make sure you are fully open at wot. Did you buy it from someone on here? |
Author: | biglinz1 [ Sun Jun 08, 2014 8:59 am ] |
No I bought it on ebay it was a coast guard boat they bought it only has ten hours on it out of water in gear or not I can get 4200 easy I will check butterfly |
Author: | biglinz1 [ Sun Jun 08, 2014 12:30 pm ] |
The butterfly opens all the way |
Author: | JLACOUR [ Sun Jun 08, 2014 12:45 pm ] |
2-3 years old with 10 hours; could be a fuel or carb issue. |
Author: | biglinz1 [ Sun Jun 08, 2014 1:01 pm ] |
It runs fine out of the water and in the water it runs good just not getting up rpms in water like when out of water is it something I am doing |
Author: | OwenDickeson [ Sun Jun 08, 2014 7:12 pm ] |
Clean the carb. |
