Any other company make high performance heads?? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=54467 |
Author: | GeeLeDouche [ Tue Jul 01, 2014 2:14 pm ] |
Post subject: | Any other company make high performance heads?? |
Im just wondering if "Iron Mountain" is the only place that sells things like aftermarket heads..?? and if anyone has used any other set and had good results? Just curious. Thanks guys! The Gee |
Author: | msm8281 [ Tue Jul 01, 2014 2:19 pm ] |
Post subject: | Re: Any other company make high performance heads?? |
Any of these cats can hook you up with a mo betta set than IM. Calen Hoyt Jamie B |
Author: | Mudmotor Slayer [ Tue Jul 01, 2014 2:40 pm ] |
Mms ![]() |
Author: | msm8281 [ Tue Jul 01, 2014 2:52 pm ] |
I thought you said you didn't do heads?? |
Author: | SCmudder7071 [ Tue Jul 01, 2014 3:04 pm ] |
Al Hodge at Performance V-Twins. |
Author: | Mudmotor Slayer [ Tue Jul 01, 2014 3:14 pm ] |
You give me 850 a set those guys charge I start doing them again lol |
Author: | AKA Freshwaterkilla [ Tue Jul 01, 2014 3:48 pm ] |
Author: | msm8281 [ Tue Jul 01, 2014 4:01 pm ] |
Author: | AKA Freshwaterkilla [ Tue Jul 01, 2014 4:10 pm ] |
Author: | ajverret [ Tue Jul 01, 2014 7:26 pm ] |
Dat kick back tho lol Sent from da mud hole |
Author: | msm8281 [ Tue Jul 01, 2014 7:32 pm ] |
Author: | cb5331 [ Tue Jul 01, 2014 7:59 pm ] |
Author: | cupped up [ Tue Jul 01, 2014 8:43 pm ] |
Anybody ever look into the heads precision cams sells? |
Author: | msm8281 [ Tue Jul 01, 2014 8:45 pm ] |
Author: | 270Handiman [ Tue Jul 01, 2014 9:06 pm ] |
Author: | LA Prop [ Wed Jul 02, 2014 8:12 pm ] |
Author: | Rooterpig [ Fri Jul 04, 2014 6:20 am ] |
Calen did mine. |
Author: | pokey79 [ Fri Jul 04, 2014 6:26 am ] |
Jamie B did mine!!! |
Author: | krogers [ Fri Jul 04, 2014 4:32 pm ] |
Author: | AKA Freshwaterkilla [ Fri Jul 04, 2014 5:04 pm ] |
Aka did mine ![]() Sent from my iPhone using |
Author: | cb5331 [ Fri Jul 04, 2014 5:07 pm ] |
Author: | benelliman [ Sat Jul 05, 2014 11:39 am ] |
A person has to be out of their got dam mind to give someone $800.00 for a set of heads!I had mine done for less than $200.00.Find a competent machine shop that does heads and do the port and polish yourself. |
Author: | odass [ Sat Jul 05, 2014 12:02 pm ] |
Author: | wisconsin phowler [ Sat Jul 05, 2014 2:11 pm ] |
Performance v-twin in North Carolina should have everything that you need... 704-291-7825 1756 Phowler 36PD |
Author: | Mudmotor Slayer [ Sat Jul 05, 2014 2:12 pm ] |
Finally a smart person !!!!!! |
Author: | AKA Freshwaterkilla [ Sat Jul 05, 2014 4:11 pm ] |
Author: | Mudmotor Slayer [ Sat Jul 05, 2014 4:43 pm ] |
Author: | GeeLeDouche [ Sun Jul 06, 2014 11:52 am ] |
So... Whats the going rate to have one of these guys work over a set of heads? |
Author: | wisconsin phowler [ Sun Jul 06, 2014 1:43 pm ] |
I think I paid $240 for decking, porting and the valve job. I went to my local speed/machine shop 1756 Phowler 36PD |
Author: | Gros'bec [ Wed Jul 09, 2014 1:51 pm ] |
Wayne at Harahan performance parts and machine shop estimates $250 to $500 depending on the condition of the heads. They use Manley stainless valves 504-737-0667 Sent from my iPhone using Tapatalk |
Author: | Jamie B. [ Wed Jul 09, 2014 2:08 pm ] |
All of this head work depends on what is actually being done to the heads. I would be willing to bet that this is single angle valve jobs, casting knock downs and smoothing and decking. There wont be any port shaping, removing of valves guides and beveling, multi angle valve jobs with no lapping compound, deshrouding, polishing of combustion chamber and exhaust ports, valve stem cutting to keep stock geometry, new valve stem seals, and so on and so on. The only reason I made this post was to make people who are unaware of what goes on with the shops that charge higher rates. It was not ment to bash in any way so please don't take it that way. |
Author: | cb5331 [ Wed Jul 09, 2014 3:55 pm ] |
^^hater |
Author: | Jamie B. [ Wed Jul 09, 2014 4:03 pm ] |
Author: | Mudmotor Slayer [ Mon Jul 14, 2014 12:17 pm ] |
Looks like La prop does head work I hear he is pretty good |
Author: | Mudmotor Slayer [ Mon Jul 14, 2014 3:35 pm ] |
Author: | THE TANK [ Mon Jul 14, 2014 4:43 pm ] |
Author: | Mudmotor Slayer [ Mon Jul 14, 2014 4:46 pm ] |
Author: | msm8281 [ Mon Jul 14, 2014 4:51 pm ] |
So many people doing heads my head is spinning...lol |
Author: | Mudmotor Slayer [ Mon Jul 14, 2014 6:12 pm ] |
Lol |
Author: | Will [ Tue Jul 15, 2014 3:59 am ] |
