It is currently Sun Jul 06, 2025 3:06 pm
Reply to topic  [ 31 posts ]
 6.0 powerstroke
Post 6.0 powerstroke
Looking at geting a new truck and came across a deal with a 6.0. Everything I read says there junk unless you bulletproof them. The one I came across was just bulletproofed and comes with warranty. .. so does the bulletproof actually make it reliable or are they just shitty motors? Figured a few here knee a little boit diesels.
1748 WC Custom 27 mini
Sat Jul 26, 2014 7:56 am
Post Re: 6.0 powerstroke
Sat Jul 26, 2014 11:33 am
I just worked on one with just under 500k on it. He bought it around 120 from a guy who had it "bulletproofed" around 100k. He said he loves it and hasnt had any real trouble out of it. Most of the trucks i've worked on that were bulletproofed, the owners were happy with them.
I do electrical work though, not a mechanic, and i've never owned one. I've worked on a good handful though.
Sat Jul 26, 2014 1:09 pm
Sat Jul 26, 2014 3:14 pm
No type of warranty on a motor that has head studs, egr delete, exhaust, all new injectors installed. At least I have not heard of it. I would not buy it. If I had it, I would fix it and keep it. New vehicles r too outrageously priced.
18'x54"CC Hanko/ 36PD
Sat Jul 26, 2014 6:06 pm
I was an international mechanic for a few years and I can tell you that a 6.0 in stock trim is a disaster waiting to happen. I assume by bulletproofing, you mean an egr delete kit and ARP head bolts? Thats a good start to a tough engine. The stock injectors suck. And the turbo is an awesome concept but it doesn't last like a cummins design. The turbine is a variable pitch so it both spools up fast and moves a lot of air. But for some reason(probably fuel related) they seem to pit and wear terribly. If you have a fairly fresh truck, less than 100,000 miles, it might be worth putting some money in. Start with a good tune. Not a shitty plug and play programmer. They push way too much fuel causing 2 weak links to get even weaker. The injectors fail bc of drastically increased fuel flow and the turbo fails bc of excessive heat and carbon build up. BUT if built and maintained properly I've seen these trucks last a long time and run great.
Sat Jul 26, 2014 6:15 pm
Bullet proof and sct programmer that's a bad boy I had one and drove the shit out of it when it get rid of it it had 300000 miles like ^ he said tho some have injector problems so don't have any
18x48 extreme with 37 gtr
past boats
07 gtr on 16x54 alweld
Sat Jul 26, 2014 8:40 pm
I have a 6.0 not bulletproofed with over 200000 miles and runs just fine. They do have weak links like every other truck. If you dont drive it with the intentions on breaking it they last.
16x48 alweld
35 gtr
Sat Jul 26, 2014 9:44 pm
Sat Jul 26, 2014 9:46 pm
Junk
Sat Jul 26, 2014 9:56 pm
16x48 alweld
35 gtr
Sat Jul 26, 2014 10:14 pm
The shop that bulletproofed the motor puts a warranty on the motor. The shop actually buys trucks with 6.0s, bulletprppfs the motors then turns around amd sales them. This truck has under a 100, 000 miles. Still undecided, seems like some think its junk and others have run the wheels off of them.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Sun Jul 27, 2014 12:07 am
Get a Duramax and not worry about it!
Excel 1851vF86 w/ MB 55V
SHIT HAPPENS
Sun Jul 27, 2014 5:25 am
It is still a ticking time bomb. Either get a 7.3 or a 6.7
Sun Jul 27, 2014 5:27 am
Ha. And a 6.7 isn't a time bomb either?
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Jul 27, 2014 6:08 am
6.6 Duramax!!!
SHIT HAPPENS
Sun Jul 27, 2014 6:12 am
Sun Jul 27, 2014 6:59 am
Sun Jul 27, 2014 7:28 am
Thanks for the help ive come to thw conclusion the 6.0 is a no go. For every story I read about one holding up well I read 5 about them falling apart and being a money pit!
Sun Jul 27, 2014 7:33 am
Duramax, or 6.7 Ford... With a warranty. It would suck selling a kidney to buy said truck, then mortgaging your house to fix it when the power plant goes south.
-Custom pool noodle
-stage 4 water wings
Sun Jul 27, 2014 8:48 am
Sun Jul 27, 2014 2:22 pm
Sun Jul 27, 2014 2:33 pm
Lbz and LMM duramax best ones to buy if you want to modify
Sun Jul 27, 2014 5:20 pm
Sun Jul 27, 2014 9:23 pm
i have the 6.7 and LOVE that motor
1748 Prodigy with MB 4500 Black Death
Mon Jul 28, 2014 6:57 am
Just did studs on a 6.0 in my shop last week...fuggin piece of shit!!! i wouldnt wish a 6.0 on my worst enemy...put studs in then an injector went out then the electric fuel pump...wiring harness's are trash...i would stay away from a 6.0
Mon Jul 28, 2014 9:53 am
7.3's are gitting mighty old. you may find a good one left but you will think its made of gold when you see the price for an at least 11 year old truck.
i have an 05 6.0, it only has 85k with egr delete and oil cooler @ 55000. turbo sticks from time to time. not sure if i could recomend one as it scares the shit out of me every time i turn the key. but its what ive got and for a 10 year old truck i havent realy had to spend much money on it.
Wed Jul 30, 2014 9:37 pm
The best thing for them besides adding a bunch of aftermarket parts is to drive them like paw paw Sun-Fri and on Sat, hammer down. Keeps everything blown out and prolongs the sticky turbo problem. If you work them hard on a daily basis that's where the stretched head bolts and leaking EGR coolers happen. The oil cooler is just junk. I changed several with less than 20K when I was at the stealership.
-Custom pool noodle
Thu Jul 31, 2014 7:38 am
Don't do it.... get a 6.7 or 6.4 ford, or a cummins. Every single duramax I have ever been around has head gasket problems, or a cracked piston, and the Allison trans loves limp mode. If you're gonna mod it, can't beat a 5.9 cummins (minus the trans) or a 6.4 ford. The 6.4 with egr and Dpf delete and a tune is a monster!
1748 Phowler with a 35 CDI MB Sport with heads, single mikuni, cam, and gutted stock exhaust
Thu Jul 31, 2014 10:40 am
Wed Aug 06, 2014 5:35 am
I have had 3 6.0's all studded and deleted, 4 7.3's, 2 24v vp cummins, 1 5.9 common rail cummins and a 08 lmm duramax. Unbiased opinion is they are all junk. It just comes down to what type of junk you like... I will say I liked my raggedy old 450k mile 12v the best out of everything I have owned and the 6.0's were a close second.
Prodigy 2066 Center Console dual rig with GTR XD L3 Deltas
Sun Aug 10, 2014 1:00 pm
Users browsing this forum: No registered users and 137 guests
