It is currently Tue Jul 01, 2025 6:17 am
Reply to topic  [ 59 posts ]  Go to page 1, 2  Next
 Painting with stencils
Post Painting with stencils
What's the best way to paint a pattern with stencils without the paint building up like hell on the stencils? It really makes a mess after a few moves of the stencil. I'm painting my boat. Got the base coat on, waiting on stencils to get here. Thanks in advance.
HOTSAUCE170 wrote:
Tue Jul 22, 2014 6:37 pm
Post Re: Painting with stencils
The kind of paint makes a difference and don't spray too heavy.
1850 & 36pd
Tue Jul 22, 2014 6:41 pm
spray your stencil on cardboard and cut with razor knife - cardboard is easier to work with than plastic flimsy stencils for amateurs like me - this worked for me after I ruined 2 stencils
Tue Jul 22, 2014 6:46 pm
Set a spot to set them down and wipe them down with paper towels or rags and rotate them. Like med said dust the paint on, not to heavy.
Did my cooler yesterday
http://www.gatorglide.com/
gatorheads@comcast.net
Tue Jul 22, 2014 6:47 pm
You base coat has a cure time.... if that window has closed you will have to sand. FYI
Tue Jul 22, 2014 6:48 pm
Tue Jul 22, 2014 6:51 pm
It camo, not a base/clear combo.
Tue Jul 22, 2014 6:52 pm
Tue Jul 22, 2014 7:03 pm
Tue Jul 22, 2014 7:06 pm
Have a few duplicate stencils. I lifted my boat on its side to help hold the stencil to the hull side.
Tue Jul 22, 2014 7:30 pm
Uh yeah mine was like 40 haha
Tue Jul 22, 2014 7:36 pm
Tue Jul 22, 2014 7:44 pm
Tue Jul 22, 2014 7:46 pm
What stencils/pattern are you going with? I would have a can of paint thinner and a few rags and just wipe it down every other move or so with the thinner than a dry rag to get the thinner off.
Basically bottomland stencils. First just some woodland shapes then a bark type deal.
Tue Jul 22, 2014 7:50 pm
If the stencil is light enough, you can use the air pressure from the spray gun to blow the stencil on the hull and then squeeze the trigger all the way to lay down the paint
Tue Jul 22, 2014 7:52 pm
Tue Jul 22, 2014 8:25 pm
Tue Jul 22, 2014 8:26 pm
Tue Jul 22, 2014 9:10 pm
Tue Jul 22, 2014 9:17 pm
If you use black don't use the kind that says paint+primer. A ton of paint comes out of them. I used new natgear stencils this last time and could paint another boat before they would need cleaning. Just don't go too heavy. I also mist the back with spray adhesive. Makes better lines and much easier to handle. You doing the bottomland likes on the havoc boats? That's a good looking pattern.
1850 & 36pd
Tue Jul 22, 2014 11:28 pm
Haven't seen a havoc. I got the idea from the prodigy boats. My base coat is gonna be a little darker green though
Wed Jul 23, 2014 3:36 am
Google havoc boat images. They are using a stencil you can get on Ebay. Looks damn good. Kinda like bottomland but better IMO. Not the digital, its the pattern that looks like bark.
1850 & 36pd
Wed Jul 23, 2014 6:15 am
Don't mean to ninja up your thread but what kind of paint did you use for the base coat and how did you prep the boat before the base coat?
Sent from my PD using a iphone
36 PD FPR PUSHING 16X48 SKIFF
Wed Jul 23, 2014 6:28 am
I actually used the hs specialties od paint that they sell at bass pro. I painted another boat I had with it then sprayed a clear coat over it and it turned out nice and held up well. I pressure washed, light sanded, wiped with acetone, and washed again for the prep.
Wed Jul 23, 2014 6:33 am
I got a bad deal on Hunter Specialty paint – bought 2 gallons that had the wrong labels on them they were supposed to be OD but were a tan color, when I got the OD finally it flaked off (in big chunks) after 1 year, probably my fault but I haven’t bought it since. Switched to Parker and haven't looked back.
Wed Jul 23, 2014 6:42 am
Wed Jul 23, 2014 6:44 am
I have the Styx river stencils that I did my boat with. To answer the ops question, light paint from about 10" away. And do multiple coats instead of globing it on in one coat. Let the stencils dry and you can break the paint off when it dries.
Wed Jul 23, 2014 6:49 am
1850 & 36pd
Wed Jul 23, 2014 6:59 am
Here's the before and during.....
Wed Jul 23, 2014 7:05 am
Jb did you thin the paint to spray it? If so what was the ratio? I'm about to paint my boat and I'm try to get as much info as I can. I don't want it to look ***** rigged lol. The boat is a skiff and I want the paint to hold up. And as far as the clear coat wouldn't that make it shine? I was under the impression that a hunting boat needed a flat or dull finish.
Wed Jul 23, 2014 7:31 am
Wed Jul 23, 2014 7:36 am
What about thinning it to spray?
Wed Jul 23, 2014 7:51 am
No thinning just poured it in the hopper. Flat clear coat to protect the paint a little better
Wed Jul 23, 2014 8:03 am
I am about to start on mine with stencils, I turned my hull over (upside down). It is going to be easy now as I won't be fighting gravity and the stencil will lay right down on the hull.
Crisis defines character
Wed Jul 23, 2014 8:23 am
Wed Jul 23, 2014 8:42 am
Users browsing this forum: Majestic-12 [Bot] and 227 guests
