It is currently Wed Aug 06, 2025 9:13 pm
Reply to topic  [ 2 posts ]
 18hp mud buddy mini hd lite
Post 18hp mud buddy mini hd lite
i have a mud buddy mini hd lite 18 hp and i am upgrading my 18hp to the 23 hp. im keeping the same frame, just taking the 18hp off and putting the 23hp on the frame. i have a 32 tooth top gear on the 18hp, and they say if im going to put the 23hp on that frame i should get the 36 tooth top gear and run a 11x10 propeller. what would the boat do and how would it run if i kept the 32 tooth top gear and ran the 11x10 propeller?? any advice on what i should do will help. thanks.
Tue Feb 10, 2009 8:15 pm
Post Re: 18hp mud buddy mini hd lite
How heavy of a load are you planning on running, also what hull are you putting it on?
If they are still running the 50 tooth bottom the 32 would give you a 1.56 ratio, the 36 a 1.38.
If your running a large/heavy hull or heavy loads the 32 would be the better choice. Light loads, light hull the 36 for speed.
I had an 04 23 Hyper with the 32/50 on a 1748 BT hull and it ran around 24 or so depending on the load.
Wed Feb 11, 2009 2:39 pm
Users browsing this forum: No registered users and 107 guests
