31 vanguard speed
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=5779
Author:  cody [ Sun Nov 01, 2009 6:30 pm ]
Post subject:  31 vanguard speed
I am about to buy a 31 vanguard inboard mudboat on a haul about 14-16 ft. long. It has a clutch! I was wondering what the average speed for the boat should be and what could i do to make it go faster?
Author:  bbb [ Mon Nov 02, 2009 9:49 am ]
Post subject:  Re: 31 vanguard engine help
I think you are asking what kind of speed can you expect from a 31 short tail on a 14-16ft boat.
If so, I would say low to mid 20's.
Want more speed, you'll need to buy some of the aftermarket parts.
You can go as fast as your pocketbook is deep.
Author:  cody [ Mon Nov 02, 2009 9:01 pm ]
no its not an outboard its an inboard engine
Author:  slambin [ Mon Nov 02, 2009 9:20 pm ]
Post subject:  Re: 31 vanguard speed
then its a mudboat. I know my buddies mudboat with a 27 kohler only went around 18 and it was a 1438 skiff. Your prolly looking around the same with the bigger hull
Author:  LA OUTLAW [ Mon Nov 02, 2009 9:28 pm ]
PM Coodik he just finished one I believe it was that size a few days ago.
Author:  bayouboy [ Mon Nov 02, 2009 9:45 pm ]
Your speed will depend on the clutches gear ratio also.
Author:  machete31 [ Tue Nov 03, 2009 10:50 am ]
That was my motor that Coondik just finished up. My boat is a Machete (Super Godevil) type unit. The stock 31 with a new prop light boat I could get 23-25 with no wind or current, 18-20 with a hunting load. If you have the ZF transmission and it has a left hand rotation prop you are looking at 1.8:1 reduction, right hand rotation is 1.4:1. I am running a 12x14 Hopkins cleaver (LH rotation) with alot of cup and tip curl. I'll assume if you set it up like a regular mudboat you would run a regular mudboat prop since the prop won't run on the surface. The engine work I just had done was shave the heads, SS valves, timing advance, 36 intake and carb, K&N filter and dual exhaust. I'm swinging the crap out of my old prop, Hopkins is currently building a new prop to match up to the engine mods I had done. I'm not really counting on much more top end but I think my load speeds will be better. One thing I can tell you, my motor never idled and ran so smooth. That Coondik dude is the man!!!
Author:  dead animal [ Tue Nov 03, 2009 12:34 pm ]
if ur turning the old prop too much, the new prop ur getting, assuming it's either bigger in dia or more pitch/cup, should bring down the rpm's and bring up the speed.
that is unless it's too much prop, then u will have to wear it out sum to be able to turn it.
good luck, those machete's are a nice rig. :)
Author:  forever draggin [ Tue Nov 03, 2009 9:32 pm ]
i ran mudboats all my life, most people i know still do, i would say mid 20s
