It is currently Mon Jun 30, 2025 6:43 pm
Reply to topic  [ 5 posts ]
 Pre-build surface drive questions???
Post Pre-build surface drive questions???
Was gonna start on a surface drive motor for next season and have a few questions. I have searched all types of threads on different forums so ill try not ask obvious ones. I have already built a longtail and ran it a full season but sold it to get a sxs. So i have a little experience.
I already have a longtail prop laying around. Could i use it? Its a 9x7 but a little wore. I need to keep the prop size 9" and under because i run a couple wma's.
If so would i run a 1-1 gear ratio since the longtails are direct drive? I seen the recommended ratios but assumed those were for sd props.
I have an idea on how to keep the shaft in place from walking ahead possibly using a locking collar on a pillar block bearing but if anybody has any insite on the way they have their shaft housing set up.
Any ideas on tilt and trim?
Im not looking to copy anybodys design but a few pointers would be appreciated
Tue Dec 23, 2014 8:13 pm
Post Re: Pre-build surface drive questions???
No on the lt prop, no on the 1:1 ratio. Need a surface drive prop. Big difference! And start around 1.5:1 for ur ratio!
35 GTR chasin a BBC 1848
Wed Dec 24, 2014 7:42 pm
Wed Dec 24, 2014 7:59 pm
Thu Dec 25, 2014 2:19 am
Im gonna do some more research on the prop. If i can get away with a lt prop for now i will.
I figured out my tilt and trim question. I was looking in 12 v electric hyraulic rams but they are classified as linear avtuators. You can find them for different weights and strokes. It will be pretty cool to have a homeade rig with working tilt
Thu Dec 25, 2014 8:30 am
Users browsing this forum: No registered users and 183 guests
